Old 09-07-2005, 04:25 PM   #1
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
Default TD04 boost control?
i have a rst. i put a td04 on as the turbo. i know on the wrx the boost is controlled by the computer(electronicly), and i know it can be put up to 19lbs. with out any boost controller it is naturally 6-7 psi. i put a manual boost controller on it and could only get it up to 8-9 psi. any tips or something im missing? looking to get 10-14 out of it. thanks
farrell is offline   Reply With Quote
Old 09-07-2005, 05:23 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
I thought the TD04 was set to 7-8 psi of boost naturally? Anyhow, it sounds like your MBC is leaking boost to the wastegate. What are you using for fuel mods, and what are you using to control fuel and timing? Thats alot of boost for a RS motor
Old 09-07-2005, 05:58 PM   #3
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
Legacy
The stock wastegate is set at 8.7 psi so i think you might have some vacume leaks and are taking away from the efficiency of the turbo. You said that you used a manual boost controler, if this did not work then the wastgate is prolly messed up.
Kawikid20o2 is offline   Reply With Quote
Old 09-08-2005, 07:38 AM   #4
SilverBullet2G
Member#: 94868
02 WRX
Sounds like your MBC has a vaccum leak
SilverBullet2G is offline   Reply With Quote
Old 09-08-2005, 03:07 PM   #5
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
how did you get the reading of 8.7 psi on the wastegate? Mine reads 6.5-7psi set wastegate on the TD04 using a turbine tester and an EBC
STi-Nismo Dood is offline   Reply With Quote
Old 09-08-2005, 04:00 PM   #6
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Are you at higher altitude than sea level? This might account for some gauge disparity.
Drac9 is offline   Reply With Quote
Old 09-08-2005, 04:06 PM   #7
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
ok i just tried to do some conversions from mpa bars to psi. at full boost with my boost controller on full boost, it reads like .045 MPa. which calculates to like 6.5 psi. i dont understand. so puzzled. please help!
EJ205 Block, Cams, TD04 IWG, OEM Boost Controller, Uppipe, & Coolant Reservoir fl4tsc Engine/Power/Exhaust 137 10-26-2009 01:32 PM
WTB TD04, Boost Control Solenoid, etc. BSpeedRacerB Private 'Wanted' Classifieds 4 02-02-2009 09:31 PM
Hallman Boost Controller, Intake, Wrx exhaust, TD04 Turbo OHARA Engine/Power/Exhaust 4 11-21-2008 08:42 PM
FS: TD04 turbo, Unichip, AVO boost Controller, Sti replica grill CtGT Private 'For Sale' Classifieds 56 06-16-2004 10:59 AM
FS: Unichip, TD04, AVO boost controller, Sti replica grill, OEM grill(aw) CtGT Rocky Mountains Impreza Club Forum -- RMIC 10 06-08-2004 12:11 PM
