Mid Atlantic Impreza Club
Old 09-07-2005, 07:13 PM   #1
D_Block
Member#: 64127
2001 PY ITR, 2012 X5
on order
Question Anyone ever replace their oilpan?
Ive had a dent in mine for a bit now, and figured next oil change I ought to replace it. Seems pretty straight forward, wondering if anyone has done theirs and can confirm that it is
D_Block is offline   Reply With Quote
Old 09-07-2005, 07:16 PM   #2
SJF01
Member#: 71021
2009 Honda FIT!!
Storm Silver
Don't wear your upscale clothing.
SJF01 is offline   Reply With Quote
Old 09-07-2005, 07:18 PM   #3
D_Block
Member#: 64127
on order
I only own white tees and bitch beaters, son!
Old 09-07-2005, 07:23 PM   #4
SJF01
Member#: 71021
2009 Honda FIT!!
Storm Silver
Originally Posted by D_Block
I only own white tees and bitch beaters, bitch!
fixed
Old 09-07-2005, 08:19 PM   #5
LotusDriftx
Member#: 48528
I managed to very mildly dent mine this weekend
not enough to have to replace it though.
I swapped the pan on the SR.
LotusDriftx is offline   Reply With Quote
Old 09-07-2005, 08:36 PM   #6
subyrally
Member#: 52662
2009 dgm WRX hatch
86 & 87 rx, 1985 brat
if its anything like the old school subies, youll have to lift your engine up about 5". i replaced the gasket on mine and the damn thing still leaks.
subyrally is offline   Reply With Quote
Old 09-07-2005, 09:37 PM   #7
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I had to replace mine on my old engine, had to lift the engine an inch or so, but not too bad. Cleaning off the old gasket material was the hardest part. New pan, new gasket, 4.5 quarts of oil and I was set to go.
speedyHAM is offline   Reply With Quote
Old 09-07-2005, 09:43 PM   #8
rhdude
Member#: 6637
2009 Acura MDX Sport
yeah just have to lift up the engine a little. Tip, use a 1/4" drive socket, extension, and U joint. Makes it so much easier. The bolts should be a 10mm. Use some gasket remover and a razor blade/scraper to get the old stuff off of the bottom of the motor. Use RTV for the new pan, don't put too much on, just an even small bead all the way around. Put it on halfway tight, then wait a couple minutes, then tighten all the way. That's what I had done when I had a dented pan, never leaked.
rhdude is offline   Reply With Quote
Old 09-07-2005, 10:05 PM   #9
D_Block
Member#: 64127
on order
Thanks for the tips. I figured I would have to jack the engine up a tad. Thats why I will do this at teh Bobs house!!
Anyone ever replaced their Rear Diff Brace?? coqui2004miguel Alaskan Impreza Club Forum -- AKIC 1 10-10-2009 05:40 PM
anyone ever replace a hard drive on their pc? db97 Off-Topic 23 06-17-2004 08:44 AM
has anyone ever lost their job and gotten drunk during lunch on their last day? monkeytronZ Southern California Impreza Club Forum -- SCIC 10 06-16-2004 09:34 PM
Has anyone ever had their tranny replaced by the dealership under warranty? skyredrex Transmission (AT/MT) & Driveline 70 03-18-2004 05:51 PM
Help...Anyone ever have their wheels milled? Whiplash Brakes, Steering & Suspension 6 05-09-2001 05:56 PM
