Old 09-07-2005, 08:25 PM   #1
EastsideLegacy
Member#: 58806
1998 RIP Legacy2.5GT
2.2L legacy wagon
Default low compression like whoa
Ok, Heres the story. First we got the heads off my old motor and got them cleaned up and put the car back together with new gaskets tourqed to the specs. Then we had like 50 pounds of compression in the 2nd cylinder. So we got another motor while we fix this one. Now i have the same motor that has only 72 thousand miles on it and cylinder 1 and 3 now have low compession.
I suspect that the first motor has bent valves ......but the second motor this is just unbelivable...
What might cause the low compression other than a bent valve or a cracked head ... if timing was off would this effect the compression in one side ....because im positive i did the timin right ...
I havent had my car for so so long and it sucks driving the camery.. so anyone if you have had the same problem or have any idea what the problem is any input helps beause my cars just sitting in the garage waiting to be fixed ...
Thanx main
EastsideLegacy is offline   Reply With Quote
Old 09-08-2005, 10:17 AM   #2
EastsideLegacy
Member#: 58806
2.2L legacy wagon
bump..
Old 09-08-2005, 11:05 AM   #3
bhall
Member#: 56015
02 WRX Wagon
05 XT Forester
I have nothing for you except maybe try over at the NA forum. Hopefully those guys can help you out.
bhall is offline   Reply With Quote
Old 09-08-2005, 11:26 AM   #4
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
piston rings, headgasket, craked block, cracked piston, bent rod, bent valve, did you do a compression test or a leak down test. Try a leak down test next. It tells alot mor than a compression test.
Russell Rogers is offline   Reply With Quote
Old 09-08-2005, 12:10 PM   #5
plasticguy
Member#: 70345
if the timing belt is not installed correctly, or slipped, you will get crazy low compression on two or four cylinders depending upon the error
many have been sure they did the timing right, and have nevertheless done it wrong
check the dot-versus-arrow on the crank pulley for a mistake, count teeth, do it all over again
btw what motor ?
plasticguy is offline   Reply With Quote
Old 09-08-2005, 08:47 PM   #6
sha_zapple
Member#: 41012
1998 Legacy L
The head could be warped
sha_zapple is offline   Reply With Quote
Old 09-08-2005, 08:48 PM   #7
EastsideLegacy
Member#: 58806
2.2L legacy wagon
Thanks for all the help ... it was the timing oh well im just so happy that its in and working nicely yea i got a whole differnt motor and now i relize i think the timing was wrong on the first one .... hmm weeellll llll all i gotta say is dont be too cocky about the timing and subarus are da bomb
Its a legacy 2.5 block nothing special i ordered cams fo it from twe but they said that they couldnt locate cores to make them outta and i didnt have the time to send mine in... oh well now i have a set of cams i can send once i get the freakin money .... thanx peoples
Thanx main
this what a low compression look like eng4280 Mid West Subaru Owners Club Forum -- MWSOC 18 04-15-2010 01:05 AM
Low Compression/High Boost vs High Compression/Low Boost? JoeTX Newbies & FAQs 31 05-18-2006 04:06 PM
What to do? High Compression, Low Boost or Low Compression, High Boost. FlooredSubaru Normally Aspirated with bolt-on Forced Induction Powertrain 6 01-29-2003 10:55 AM
Tuning hp and torque curve w/ low compression and high compression pistons FuJi K Normally Aspirated with bolt-on Forced Induction Powertrain 22 10-14-2001 07:25 PM
