#1 |
Member#: 87463
Vehicle:2004 STI AspenWhite |
so what is the different?
I had an Zerosports JDM spec CBE and i compared to my STI oem CBE and they have no difference in lenght... so I dont get it... is it the difference is in the downpipe section? please help me to understand it. thanks
#2 |
Member#: 70285
Vehicle:2011 JCW Mini Midnight Black/Red roof |
yes, the dp IS different on jdm cars, its longer by about 10+ inches.
#3 |
Member#: 13520
Vehicle:99rs ej207 spec-c its for sale |
jdm downpipe is shorter, usdm longer, becuase usdm cars have the 3rd cat and jdm cars dont
#4 |
Member#: 48401
SCIC
Vehicle:05 sti 08 cbr600RR |
^^^ what he said I have a jdm tbe on my car and the dp is shorter by about 5-7in. and if you notice most exhaust coming from jp taper to 2 and a quarter to fit the stock donut gasket.
#5 |
Member#: 65536
Vehicle:05 Impreza | STi Simple.less is more. |
yes. If you buy a JDM exhaust, you need a JDM dp to fit on your car.
Kakimoto with Cusco Dp or RS-R Dp etc... |
#6 |
Member#: 70285
you guys must be on crack or something my dp i WAY longer than USDM (RS*R)
#7 |
Top Scoob 002
Member#: 32771
BAIC
Vehicle:03 Black WRX 04 White M3 |
that is because you have the RSR downpipe designed to work with their turboback exhaust. Look at other JDM downpipes and you will see they are alot shorter.
#8 |
Member#: 87463
interesting, i have zerosports cat back and it will fit on the cat from the dp. so.... i am guessing using a JDM DP will take out the cat in between the exhaust and dp. if using USDM spec dp will still need the cat in between them...
this is just my guess... |
#9 |
Member#: 45323
South East
Vehicle:MY05 Impreza WRX STi Pastelito Racing & SFSOC |
Ok,
The JDM Downpipe is one piece. The USDM Downpipe is two piece, and includes a third cat. If you look at the USDM Downpipes Rear 02 sensor that is where the JDM Downpipe stops (just after). Sure the flanges will match to a USDM Downpipe b/c they are the same diameter pipe but the length isn't correct. Since the USDM downpipe is two pieces you could take the 3rd cat pipe out and get some custom pipe bent to go from USDM shorty to JDM Catback. CF: JDM Catback use JDM Downpipe USDM Catback use USDM Downpipe simple as that. |
#10 |
Member#: 87463
so confuse now... any pictures to show the differences?
#11 |
Member#: 45323
South East
I'll look for some later.
Do a search for JDM vs USDM downpipe |
#12 |
Member#: 87463
http://forums.nasioc.com/forums/showthread.php?t=842009
borrowing from the thread above. JDM will cover both cat and still have a 3rd cat? if that is the case, our cars have so many cat..... thanks for the help |
#13 |
Member#: 41477
NESIC
Vehicle:2006 Tahoe that will pull your bumper off |
looking at this picture, It shows a USDM aftermarket downpipe.
http://forums.nasioc.com/forums/show...62&postcount=3 the JDM Downpipe would stop right after the 02 sensor bung, and be one piece The JDM Downpipe has one Cat right after the turbo. |
#14 |
Member#: 65536
so the RS*R downpipe won't fit with the kakimoto exhaust?
| Thread Tools | |
| Display Modes | |
| 04 JDM STi and USDM 04 STi flywheels | triniscoob | Transmission (AT/MT) & Driveline | 0 | 03-16-2007 03:00 PM |
| jdm sti and usdm wrx | response | Factory 2.0L Turbo Powertrain | 0 | 01-25-2004 08:40 AM |
| JDM STI and USDM WRX parts | downshift1 | Private 'For Sale' Classifieds | 70 | 01-09-2004 05:35 PM |
| JDM spec and US spec? | hitman912 | Engine Management & Tuning | 2 | 12-01-2003 10:17 PM |
| Euro Spec V's USDM Spec STI | cannyboy | STi Forum Archive | 5 | 09-09-2003 10:43 AM |
