Mid Atlantic Impreza Club
Old 09-08-2005, 12:18 AM   #1
SupraScooby
Member#: 52123
05 WRB STi
04 AW STi GT30R [RIP]
Default HR: Need AVC-R help!
If anyone experienced with the apexi avc-r ebc could lend me a hand with setting a target boost, it would be well appreciated! Thanks!
-Jon
SupraScooby is offline   Reply With Quote
Old 09-08-2005, 08:14 AM   #2
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Hey I just installed mine, it was a piece of cake. What exactly are your problems?
Basically all you have to do is get the unit to learn your duty cycle setup, then you can modify the settings from there including target boost and start duty per gear. Start by reinitializing the unit to default, set the number of cylinders to 4, then go into “Duty Cycle” and set the target boost value to 1.0Kg/cm^2 and the duty cycle value to 55%. Now go do a few 3rd gear pulls and the system will learn the correct curve. Once it learns the duty cycle value should say "***" meaning it was set by the system.
Once this is in place you can then go in and change your settings including increasing target boost. I have my target boost set to 1.2Kg/cm^2 (17psi) and my Start Duty set to +4 in first and +2 in second. This allows first and second gear to spike so you can reach target boost in those gears. If you experience too much spike or unstable boost you can go and mess with the F/B settings too…
This is a good thread from other users about the system setup:
http://www.clubwrx.net/forums/showth...highlight=avcr
And of course the manual:
http://www.apexi-usa.com/pdfInstallation/21.pdf
Good Lucks...
xcntrk75 is offline   Reply With Quote
Old 09-08-2005, 08:18 AM   #3
SupraScooby
Member#: 52123
05 WRB STi
I'll try that, thanks!
Old 09-10-2005, 01:06 PM   #4
SupraScooby
Member#: 52123
05 WRB STi
Well I made sure that my avc-r was set to gear learning O (not the X), set the boost to 1.0kg/cm² w/ 55% duty cycle and did a couple of 3rd gear pulls. The problem is that I can't get the duty cycle to say "***" Am I doing something wrong? Am I supposed to only allow 3rd gear to be learning or all?
Old 09-10-2005, 02:20 PM   #5
wrxtuner13
Member#: 88521
2010 WRX Sedan
390whp/398wtq E85
hey new to the area came up from jax fl. Just wanted to say hey and hoped some one would point me to the meets and stuff.
thanks
jeremey
wrxtuner13 is offline   Reply With Quote
Old 09-10-2005, 02:23 PM   #6
D_Block
Member#: 64127
2001 PY ITR, 2012 X5
on order
thanks
jeremey
Hey genius why dont you just pm me. There is a party at my house today..if you want to come by the thread is here...http://forums.nasioc.com/forums/showthread.php?t=842567
D_Block is offline   Reply With Quote
Old 09-10-2005, 02:36 PM   #7
SupraScooby
Member#: 52123
05 WRB STi
back on topic!
HR: need help January 1, 2 carsnrockmusic Mid Atlantic Impreza Club -- MAIC 4 12-27-2005 11:09 AM
HR: need help finding new carmax or like minded place in Va beach LotusDriftx Mid Atlantic Impreza Club -- MAIC 10 07-19-2005 04:53 PM
HR: Need help tuning distributor/carb UGotBoost? Mid Atlantic Impreza Club -- MAIC 13 04-26-2005 06:03 AM
HR: Need some help! SupraScooby Mid Atlantic Impreza Club -- MAIC 7 04-24-2005 12:36 PM
Help needed.....AVC-r wiring WRX Ver.7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-15-2003 12:54 AM
