Old 09-08-2005, 10:52 AM   #1
kpiazzis
Member#: 69640
Default Wires came out of oxy sensor plug. Need help
I replaced my transmission on a 1996 Legacy. The plug that goes to the front oxy sensor would not release when I pressed the little clip and pulled. What happened is that the 3 little metal clips pulled out from the connector. I can put them back into the plug, but I don't know where they go. The oxy sensor has two white wires and a black wire. On the car harness side I have a yellow w/red stripe, a white wire, and finally a black wire. I need to know how to connect these back together. Can anyone help.
Thanks
Kevin
kpiazzis is offline   Reply With Quote
Wires came out :( HELP! BoXinWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-17-2009 02:05 PM
Wire pulled out of an ABS sensor - does this affect the DCCD? JWA Brakes, Steering & Suspension 0 08-07-2007 12:10 AM
Rubbing the hell out of my tires!! I need help Halshara Brakes, Steering & Suspension 11 12-28-2006 03:50 AM
Greddy guage...wire came out...where does it go? shemoves Electrical & Lighting 0 09-09-2005 05:15 PM
