Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 09-08-2005, 05:49 PM   #1
gavinl
Member#: 57891
2005 9-2x Aero
Default Coil pack ok?
Just tested my 97 OBS coil pack, here are the readings from the Multimeter:
primary terminals
1-2: 1.1ohms
2-3: 1.1ohms
Secondary terminals
1-2: 12.7k ohms
3-4: 12.89k ohms
The primary resistance seems a tad high compared to factory spec of .73ohms but not high enough to be open circuit. Is my coil pack ok?
gavinl is offline   Reply With Quote
Old 09-08-2005, 07:26 PM   #2
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
Not good with electricity. My question is, are you having a problem with it? Why did you perform the test?
t3hWIT is offline   Reply With Quote
Old 09-08-2005, 08:12 PM   #3
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
If you subtract the resistance of the meter leads (.3 to .8 ohms), your readings will be within spec. But that doesn't mean the primary coil doesn't get overheated and have intermittent open circuit.
2slofouru is offline   Reply With Quote
Old 09-09-2005, 01:02 AM   #4
gavinl
Member#: 57891
2005 9-2x Aero
Reason I asked was I just mis-timed my 2.2 motor causing severe misfiring and bent valves. I'm wondering if during the misfiring might the coil been shorted out.
Old 09-09-2005, 01:29 AM   #5
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
That would not cause the coils to go bad.
Old 09-09-2005, 07:42 AM   #6
kaisersouse
Member#: 85900
2001 Forester S
somewhat related: i noticed on my coil pack/distributor/whatever that 3 of the contacts were a nice bright gold, and one (#4 i think, the one on the rear-right if youre facing it) was oxidized. I cleaned it with a wire brush, but i read somewhere that its a sign of a bad coil pack.
kaisersouse is offline   Reply With Quote
Old 09-09-2005, 09:48 AM   #7
Pat L.I.
Member#: 20498
2006 WRX TR
where did you read that? do you have any more information or a link?
here is my thread from a while ago. it never really got answered.
my car is in the shop right now, i asked them to look at the coil pack.
bad coil pack?
Pat L.I. is offline   Reply With Quote
Old 09-09-2005, 03:11 PM   #8
gavinl
Member#: 57891
2005 9-2x Aero
Hey kaisersouse, I also did notice my coil pack having a oxidize secondary terminal for cyl #1 after the car sent a cyl #1 misfiring error code. Cleaned that up and car was running fine till I f-ed up the timing belt and bent the valves.
Now I just wanna be sure that I have decent enough ignition parts to fire up a reman long block I just bought from CCR.
FS : Misc WRX parts, 3 Port BCS, T-stat, Balancer, TGV, Coil pack lethaldose Engine/Power/Exhaust 14 07-23-2010 06:28 PM
Tach or Coil pack, I have to choose? tenchu Pre-2002 Factory Turbo Powertrain 10 06-03-2010 01:40 AM
WTB: WRX coil packs for the EJ20G coil pack conversion ASAP! Joshb120 Private 'Wanted' Classifieds 2 05-18-2008 01:42 AM
4 Wrx Coils, Ignition Coil Packs, navyissuesuby Private 'For Sale' Classifieds 16 03-05-2005 02:07 PM
Coil and coil pack brunetmj Electrical & Lighting 6 02-01-2003 10:38 AM
