Old 09-08-2005, 05:55 PM   #1
bootleg23
Member#: 83937
Default help, check engine light
Hey
I have a 93 legacy L and I am wondering how do I pull codes from the ECU?
the check engine light is flashing
Thanks
bootleg23 is offline   Reply With Quote
Old 09-08-2005, 06:35 PM   #2
VOLTIS5
Member#: 2353
98' LegOver GT
dark whiteish pearly red
take it to a stealership or have someone with a universal scanner hook it up for you.
VOLTIS5 is offline   Reply With Quote
Old 09-08-2005, 06:35 PM   #3
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
go to your local autozone/schucks/stealership and have them pull the code for you. I imagine you are OBD I. There is a way I believe to get the CEL to flash a sequence back to you so that you can decipher it that way too. Search in the N/A forum and you might be able to find something.
good luck
Jared
gtwagon941 is offline   Reply With Quote
Old 09-09-2005, 10:15 AM   #4
plasticguy
Member#: 70345
go to www.legacycentral.org and search the bboards there, all your questions will be answered
the "Libarary" section has the procedure you are looking for
plasticguy is offline   Reply With Quote
HELP! Check Engine light on & Cruise Control Light Blinking STiURBO Southern California Impreza Club Forum -- SCIC 21 03-15-2007 01:54 AM
HELP!!!!!Check engine light and cruise light on joe198219 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 01-17-2006 07:07 PM
help check engine light and abs light??? greentre Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-15-2002 05:11 AM
Help! Check Engine light on! SubieFL Technical Forum Archive 11 09-22-2000 05:17 AM
Need Help-Check Engine light is on AndyHidley Technical Forum Archive 3 05-19-2000 01:35 PM
