Old 08-20-2001, 04:42 PM   #1
Benjamin Tang
Member#: 4496
2009 Forester
red
Default ej22 and 2j25 drive belts same?
reason being is that i bought an underdrive pulley with belts from a 2.5 gt that i want to install on our ej22, and i don't want to find out after the pulley is off that they don't work
ben
Benjamin Tang is offline   Reply With Quote
Old 08-20-2001, 08:28 PM   #2
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Default Re: ej22 and 2j25 drive belts same?
ben
Yes, but. I bought an underdrive pulley that came with the correct belts, but they still didn't fit. Too long. I needed something about 5cm shorter than what they supplied. However, another OB owner was fine with what was too long for me. It may be a difference between manual and auto, but I doubt it as the stock part is the same number. What numbers are yours?
rrubel is offline   Reply With Quote
Old 08-20-2001, 11:41 PM   #3
Benjamin Tang
Member#: 4496
2009 Forester
red
it was from an ej25 manual. ours is an ej22 auto.
the 2 belts supplied have napa parts numbers... 25-050336 and 25-040335?
ben
Old 08-22-2001, 06:22 PM   #4
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
ben
I believe that 336 is incorrect - I had to get a 330 instead. I was sent a 336, found it WAAAAY too long (broke the tensioner bolt ONE day before a vacation :-), tried a 325, found it too short, and eventually was given a 330 by the guy who re-welded the bolt. Neat trick, btw - weld a nut to the top of the broken bolt to replace the head. The 040335 should be fine if that's the driver's side belt.
Hope this helps. And be *very* careful not to overtorque the tensioner bolts.
Old 08-22-2001, 07:09 PM   #5
Benjamin Tang
Member#: 4496
2009 Forester
red
i'm too chicken*hit to do it myself... my local sube dealer is going to do it (believe it or not).
i bought the pulley and belts used off an ej25 gt, and it worked on that car. dealer says stock belt sizes between the ej22 and ej25 are the same, so.... here goes?
ben
WRX STi Gates Racing Power Steerring and Alternator Drive Belt New tolishel Engine/Power/Exhaust 0 07-22-2009 06:28 PM
Need help with Drive Belts: Front Sdie Belt and Rear Side Belt clbd39 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-23-2008 04:28 PM
Are all EJ22 Intake Manifolds and Throttle Bodies the same? Zac86 Legacy Forum 1 11-19-2008 02:53 AM
95 legacy ej22 and 96 outback, are they the same machine4321 Legacy Forum 7 05-13-2007 11:24 PM
Pay shop or DIY Timing Belt Tensioner and inner drive belt erikkellison Service & Maintenance 23 02-26-2005 02:28 AM
