#1 |
Member#: 83271
Vehicle:2004 STI Aspen White |
Where is the best spot to put the sending unit(defi)??
I searched, and came up empty. Thanks in advance for the help. ![]()
#2 |
Member#: 65145
Vehicle:2005 Sti WR Blue |
Here are two options for you. I was planning on using the oil filter sandwich adapter one when I finally get around to getting my gauges. Hope one or the other works out for you
![]() http://www.rallysportdirect.com/shop...Path/59_60_315 |
#3 |
Member#: 65054
Vehicle:2005 Grannymobile Hitch + Block Heater |
#4 |
Member#: 32574
Vehicle:2004 STi WRB 402whp/400wtq |
I have an oil cooler kit that uses a sandwich adapter so I tapped a hole in the side of the sandwich adapter and ran it there. Works perfectly.
#5 |
Member#: 65145
WolfPlayer, awesome pics, thanks!
| Thread Tools | |
| Display Modes | |
| Need to borrow a Defi Oil Pressure Sending unit | Daddy's SCP | New England Impreza Club Forum -- NESIC | 0 | 10-31-2006 09:43 AM |
| oil pressure sending unit | imprezzakc | Normally Aspirated Powertrain | 5 | 08-07-2003 09:22 PM |
| How does the factory oil pressure sending unit work? | Jasno999 | Factory 2.0L Turbo Powertrain | 3 | 09-13-2002 02:16 PM |
| Autometer elec. oil pressure sending unit tap location instructions | joostin420 | General Forum Archive | 1 | 02-08-2001 09:39 AM |
| you don't have to bleed the hose that goes to the oil pressure sending unit....??? | rao | Normally Aspirated Powertrain | 1 | 10-25-2000 12:36 AM |
