Old 09-09-2005, 01:30 AM   #1
gharari
Member#: 66695
2006 STI
Obsidian Black Pearl
Default Engine Management for a 2005 RS
I'm looking for engine management for my 2005 RS (MAF). My interest was sparked after reading about the PerfecntPower piggy back units as well as I-Speed's RS reflash (which showed about 10HP improvement on a 2.2L).
I am looking for engine management that will be able to tune both closed loop and open loop ranges (all RPMs).
Something like a Cobb Accessport would be ideal for the convenience of changing maps and custom tuning.
Anything out there like this for my car?
gharari is offline   Reply With Quote
Old 09-09-2005, 01:59 AM   #2
CatchMyDrift
Member#: 54523
Perfect Power from www.rallitek.com
I believe thats your only option. There is something different about the new RS that cant use anything else. Or so ive heard.
CatchMyDrift is offline   Reply With Quote
Old 09-09-2005, 03:16 AM   #3
Chi_San
Member#: 53558
2002 WRX Wagon
And, if you're planning on running boost in an RS? UTEC?
Chi_San is offline   Reply With Quote
Old 09-09-2005, 05:47 AM   #4
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
UTEC is not designed to work with an RS ECU, so don't even try. Since you have an 05 your only option is to go wth the PP. I know when the PP first came out you were only able to tune it in closed loop, but since then they have been trying to make it so you can tune both open and closed loop. Not sure what the status of that is though. You should call Rallitek and ask them. The nice thing about the PP IMO is that you can have two different maps, and switch between them on a laptop. Plus with the ability to tune with a laptop, you can make small changes as you do more mods to the car, where as with a reflash you would have to do it all over again. If I'm correct I even read on the Rallitek forum that they are trying to work on taking out CEL coeds, and raising the rev limiter. But, like I said, give them a call and ask them everything you can about the PP. IMO it's probably the best unit out untill I-speed can get some maps made, and handle all the stuff that the RS owners would like.
X4 SRT is offline   Reply With Quote
wtb engine management for 98 rs fourbyman Private 'Wanted' Classifieds 0 02-13-2008 08:46 PM
Need Engine Management for 2000 RS-T!!! CurlyPete Engine Management & Tuning 2 10-04-2003 08:32 PM
engine management for EJ25 swap? RaceCarRiot Normally Aspirated Powertrain 8 03-24-2002 11:22 AM
AEM Engine Management for WRX!!!! mcu81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-14-2001 02:50 AM
Engine managment for PE 1818 / 1820 Branwell Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-04-2001 11:09 AM
