Old 09-09-2005, 02:27 AM   #1
HannesRacing
Member#: 50272
2001 JDM WRX
MRT XB-Kit 185kw (atw)
Default What to look out for after crash repair?!?!
Hi,
last week I was unfortunate enough to loose control of my WRX on a wet road and rolled it down a 20 m bank( sounds much worse than it was, wasn't going that fast). The roof above the drivers seat is dented in by about 20 cm and the front and left side window are smashed. The bonnet is dented in by about 10 cm above the left light and panels are also pushed to the left, as can be seen because there is no more gap between the hood and the panel above the right front wheel. Apart from other panel and paint damage the main problem seems to be the right rear wheel. Some connection snapped and the top of the wheel is pointed inwards on a 45 degree angle. Fortunately insurance will cover everything and at the moment they are assesing if a repair is economic for them. Most likely it will be, and I was just wondering what to look for after the car has been repaired? Any important things to be wary of ? I was thinking about alignment of the chassis etc... Advise would be greatly appreciated.
HannesRacing is offline   Reply With Quote
Old 09-09-2005, 02:34 AM   #2
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
I hope you didn't get shaken up too badly. Go see a doctor if ANYTHING feels outta whack.
From what you described, it sounds like a totalled car. I am suprised they are thinking about fixing it. I would reject any repairs they do to it, at which point they will hopefully total it and hand you a check, after some whining.
You should post a few pics of the carnage.
specialev is offline   Reply With Quote
Old 09-09-2005, 03:15 AM   #3
5.0Ranger
Member#: 93546
08 wrx
pearl white
I would be very careful about letting the insurance fix a car that damaged. I don't care how fast you were going if you rolled a WRX it's going to have serious damage.
If the damage is isolated to one area of the car, The shop might just cut that end off and weld on a new one. Need less to say that's just asking for trouble down the road.
Usually in a major repair job like that the shop will overlook corrosion protection and environmental sealing. Not to mention the paint won't last as long as the factory paint job.
I am kinda generalizing here but, it's just my experience. Hard to really say if repairs should be made or to just total the car, without seeing the damage. Post some pics if you can...Good Luck!
5.0Ranger is offline   Reply With Quote
Old 09-09-2005, 10:34 AM   #4
Wagon Of Fury
Member#: 47982
I agree with everything Ranger said except this. The Subie factory paint job barely stands up to having a kitten lick it. I can scarcely imagine a weaker paint job. Good luck on the repair.
Wagon Of Fury is offline   Reply With Quote
Old 09-09-2005, 10:35 AM   #5
SixSick6
Member#: 76658
get rid of it start over.
SixSick6 is offline   Reply With Quote
Old 09-09-2005, 10:58 AM   #6
IntraWRX
Member#: 20773
Midnight Black Pearl
i'm gonna have to agree with wagon from hell on this one
IntraWRX is offline   Reply With Quote
Old 09-09-2005, 11:23 AM   #7
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Yes. Almost any paint put on by a good body man is gonna be a helluva lot thicker than the factory paint.
I still wouldn't want that car back.
Old 09-19-2005, 08:16 AM   #8
HannesRacing
Member#: 50272
2001 JDM WRX
Default Damage not as bad
Good news from the repair shop: damage is only half as bad as it sounds, apart from afew panels and right rear suspension nothing is damaged. Insurance pays for everything and damaged parts will be replaced with new ones, no repairs whatsoever. And the best thing is I can use the opportunity to get the car repainted in a better colour
- can't post pics admin doesn't let me
Old 09-19-2005, 09:29 AM   #9
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
Sounds good, just check the car over thoroughly when you get it back, test drive it and make sure all sounds good with the car. Any wierd creeks and or things like that, take it back immediately.
kero is offline   Reply With Quote
Old 09-19-2005, 11:19 AM   #10
Lethargic1
Member#: 20998
That's cool man. Post pics of your old and new color when you get a chance.
Lethargic1 is offline   Reply With Quote
Looking for a used Cobb AP V2 - what to look out for? sensinitas Newbies & FAQs 6 02-13-2009 08:39 PM
Looking to purchase a 06 wrx 5spd in june or july. what to look out for? Ahut2000 General Community 0 04-09-2008 10:06 AM
About to buy 99 Legacy with 2.2L motor - What to look out for? mgs333 Legacy Forum 8 04-26-2007 08:36 PM
Driving to Montreal, tips/what to look out for? balajc Tri-State Area Forum 37 07-12-2005 07:17 PM
looking to buy a suby... What to look out for? custmguru Outback Forum 0 02-25-2004 02:57 PM
