#1 |
Member#: 51141
Vehicle:2013 WRX PBP |
Recently my car (02 2.5 RS) has started hiccuping. At idle, every few seconds there is a studder or hiccup and you can feel the car shake for a second. Once and a while under acceleration it will do it also. I thought maybe it was bad gas, but I filled up today, differnt station and same thing. No CEL's or anything. I am really confused as to what this can be, anyone have any ideas?
Thanks
#2 |
Member#: 51642
TXIC
Vehicle:2001 Impreza RS BRP |
I'd check the coil pack, look for corrosion.
When was the last time you changed the fuel filter? Two good places to start. |
#3 |
Member#: 85900
NESIC
Vehicle:2001 Forester S White |
also check plugs/wires
#4 |
Member#: 90539
South East
Vehicle:95 L with ej20k powa, Raven R6 |
Mine does the same thing but I have 2.5d and 1.8 ecu with bigger exhaust.
My plug wires appear to be original and the coilpack measured fine. I also swapped coilpack with my other from the 1.8 and the same hiccup. I have one month old NGK plugs. Where is the best place to get plug wires for the dohc other than the dealer? I don't want to get some generic "super spark" or "sparkarama" from Hilo or autozone, etc.. |
#5 | |
Member#: 51141
Thanks |
#6 |
Member#: 51642
TXIC
My car hiccups after every fill up. People say it is probably due to the sediment in the fuel tank being stirred up
I'm not sure. Still happens, but it was a lot more like a buck before I swapped out my fuel filter.Was thinking. May even be, ever so slightly, the A/F sensor (or front oxygen sensor). How has your mileage been? If its still ok then your mileage shouldn't be effected too much. |
#7 |
Member#: 51141
Mileage has been fine.
| Thread Tools | |
| Display Modes | |
| Someone give me the cure for hiccups...damn it! | xfactor834 | Off-Topic | 28 | 01-22-2004 11:26 AM |
| Chirp, hiccup, misfire. | jamz | Factory 2.0L Turbo Powertrain | 0 | 06-14-2003 08:28 PM |
| Diagnosing Power Hiccup | Introspector | Factory 2.0L Turbo Powertrain | 3 | 04-28-2003 11:17 PM |
| weird hiccupping under acceleration | RaceCarRiot | Normally Aspirated Powertrain | 5 | 05-31-2001 05:49 AM |
| Car hiccups occasionally on acceleration? | Fred Fredburger | General Forum Archive | 18 | 01-07-2001 12:40 AM |
