Old 09-09-2005, 02:00 PM   #1
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Default Help. Car will not return to idle...
I just installed smc's alcohol injection kit and when i was going through the test in the directions I ran into a problem. I was running it at 3000 rpms and I hit the test button. There was a slight stumble as there should be. I released the test button and let off the throttle but it would not return to idle. I tapped the throttle and the rpms went higher but again it didn't come down. I checked the throttle cable at the throttle body and nothing appears to be hung.
Is it possible that the IAC got screwed up by the water?
LiquidForce is offline   Reply With Quote
Old 09-09-2005, 04:00 PM   #2
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
i had a similar symtoms when i pulled my bov off for cleaning and redoing my recirc hose..not sure if it could relate to your problem, but it appeared my throttle position sensor was reading wrong. Reseating the sensor plug and undoing my neg battery cable for a few min sorted it out. My throttle and idle went back to perfect.
fastnoypi is offline   Reply With Quote
Old 09-09-2005, 09:21 PM   #3
LiquidForce
Member#: 12811
2002 2.5l Wrx
fastnyopi,
I cleaned the IAC , reseated the tps plug and reset the ecu by unhooking the neg cable and pressing the brakes. When I first restarted the car it went right to 3000 rpms and threw a cel (p1507). While I was checking under the hood the idle settled back down to 750. I reset the ecu one more time to clear the code and everything appears to be fine now.
thanks
Mike K
Old 09-09-2005, 10:07 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Originally Posted by LiquidForce
fastnyopi,
thanks
Mike K
.....get some LPS2 from ACE hardware and take the IAC valve back off and spray the inside of the valve with it....it will lube it and help prevent it sticking.
Mine was REAL sticky and I did the above and it is all good since.
Old 09-09-2005, 11:49 PM   #5
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
fastnyopi,
thanks
Mike K
awsome man..glad things worked out
09 wrx throttle hangs / does not return to idle Erik F Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-22-2009 12:33 PM
steering will not return to center gmanwrx Brakes, Steering & Suspension 4 01-17-2008 08:22 PM
Car will not rev and idles very low dbridge005 Newbies & FAQs 22 02-28-2007 10:55 PM
need help car will not fire 387hardcore Pre-2002 Factory Turbo Powertrain 2 05-03-2004 12:58 AM
need help car will not run 387hardcore Tri-State Area Forum 20 03-22-2004 01:29 PM
