Old 09-09-2005, 02:26 PM   #1
abosworth
Member#: 53856
2012 Speed3
Red Mica
Default Question about Grounding mod..
I was reading about the "grounding mod (hesitation fix)" and i just have one question. I know where to connect the new grounds but how do you get all three of these connected to the negative batery terminal? Pics would be nice. i looked all through the thread that is in the faqs for this forum and i did not see any pics. do you just attatch them to the bolt on the negative batery cable, or do you attatch them directly to the batery?
Thanks,
abosworth is offline   Reply With Quote
Old 09-09-2005, 02:39 PM   #2
kaisersouse
Member#: 85900
2001 Forester S
Thanks,
bolt on the negative cable where it connects to the battery
kaisersouse is offline   Reply With Quote
Old 09-09-2005, 02:51 PM   #3
DreddRS25
Member#: 51642
2008 WRX
You could use one of the other grounding points as a junction for all the ground wires. What do they call that? I think a Single-Point-Grounding scheme.
Check out this photo for an idea.
http://www.camotoy.com/products/pictures/rswires.jpg
DreddRS25 is offline   Reply With Quote
Old 09-10-2005, 07:22 AM   #4
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Go to your local hardware store with your wire in hand and pick up a 1/4" ring terminal capable of handling all the wires. Crimp it on and hook it up the negative terminal on the battery. I hope the mod actually does something for you other than make your wallet lighter.
specialev is offline   Reply With Quote
Question about Ground Control Coil-Overs Spectre186 Brakes, Steering & Suspension 4 01-15-2005 02:06 AM
question about ground control scoobydorift Brakes, Steering & Suspension 13 03-19-2004 01:54 AM
Question about grounding Mod install... Matty Electrical & Lighting 2 01-01-2003 05:51 PM
Question about Ground Control Coilover Sleeves Night Kid Brakes, Steering & Suspension 14 12-10-2002 03:28 AM
petty questions about Ground Control and KYB AGX Henry Brakes, Steering & Suspension 21 09-06-2002 12:48 AM
