Old 09-09-2005, 03:11 PM   #1
rayyoung05
Member#: 93771
Default small or big tires?
does any one know if its beter to have biger tires or smaller tires wich is faster not regarding to tire width
rayyoung05 is offline   Reply With Quote
Old 09-09-2005, 03:24 PM   #2
Nicklbrso
Member#: 44887
00 GC6
wrong forum
Nicklbrso is offline   Reply With Quote
Old 09-09-2005, 03:28 PM   #3
GuyLR
Member#: 21811
2003 WRX Wag/01 OBS
WRB and SM
Originally Posted by Nicklbrso
wrong forum
In this forum it's better to have a big engine than a small one
GuyLR is offline   Reply With Quote
Old 09-09-2005, 03:58 PM   #4
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
you mean like diameter?
svek is offline   Reply With Quote
Old 09-09-2005, 04:20 PM   #5
LunaticDriver
Member#: 95411
1990 Miata Holla Up!
i think he means the profile of the tire
LunaticDriver is offline   Reply With Quote
Old 09-09-2005, 05:31 PM   #6
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
I moved up to 215/50R17's. At 120mph on the speedo means I'm really doing about 125-126mph. Kept on passing the older GS300 just last night.
You would be losing some torque to gain horse power.
CitySubie is offline   Reply With Quote
Old 09-09-2005, 05:49 PM   #7
burnera
Member#: 56232
89 325I
i don't know
umm, no.
you sacrifice torque for RPM (the wheel not the engine)
burnera is offline   Reply With Quote
Old 09-09-2005, 06:13 PM   #8
Lethargic1
Member#: 20998
Originally Posted by burnera
umm, no.
Yeah, but if you have the same amount of torque moving 15"s and then they have to move 16"s, technically wouldn't it make your car slower from the start? I guess I just don't understand your comment. Can you elaborate?
Lethargic1 is offline   Reply With Quote
Old 09-09-2005, 06:23 PM   #9
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
You wouldn't gain torque or horsepower moving to bigger wheels. Weight pushed aside, if you had a wheel that was 15" in diameter and a wheel that was 16" in diameter. It would be harder to move with the 16" wheel because you have to move an extra 3.14" in the same turn than with the 15" wheel. Its goin to take more torque to do that in the same amount of time was the 15" wheel.
The benefits of using a larger wheel with a smaller tire is that you can get better handling from it, you can enter and leave corners faster. But you can't accelerate as fast.
Old 09-09-2005, 06:27 PM   #10
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
umm, no.
It's physics. A breaker bar is used to make twisting easier, more torque is applied from the same weight pushing down on the handle of the breaker bar. A tire with a larger diameter is harder to twist from the axle then, let's say a 10" diameter tire. The 10" diameter tire will spin a lot easier, but will not cover the same distance as my 25" diameter tire.
You do lose torque with a larger tire.
And horse power is energy being translated into speed. With a larger tire, you gain horse power.
I didn't make it up. Physics did.
Old 09-09-2005, 06:30 PM   #11
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
BTW, I was talking about the overall tire size. Not rims size assuming all weight and dimension (except diameter) stays the same.
small problem or big problem? revenance Transmission (AT/MT) & Driveline 4 06-10-2008 09:04 PM
Whats faster, big torque or big HP, same outputs... reddevil Proven Power Bragging 14 06-22-2006 04:38 PM
Brand New Kicker Solobaric Subwoofers... CHEAP... small box, big boom RossWRX Private 'For Sale' Classifieds 14 04-18-2006 06:49 PM
Who's got big tires on a GM8 or GC6? BongMan Brakes, Steering & Suspension 6 01-01-2003 03:19 PM
