Old 09-09-2005, 04:13 PM   #1
LunaticDriver
Member#: 95411
1990 Miata Holla Up!
Default 2001 2.5RS what are the widest tires on a stock body?
Going wheel shopping too and wanted to know what are the widest you can fit on the 2001 2.5 RS's stock body before you need to roll the fenders or something like that...
*edit* doh just saw the tire and wheels area i feel stupid can a admin move this?
LunaticDriver is offline   Reply With Quote
Old 09-09-2005, 08:03 PM   #2
Lavery
Member#: 77896
98 impreza 2.5rs
Be careful trying to go to big...i'm running 225/40/18s on +42 wheel offset. the combination of those two make it rub. i rolled the fenders and i am running -1 degrees of camber.
long story short, 225s are probably fine if the wheel offset is around +50 which is where it should be. (+53 stock) or 215s with the offset i have
make sense?
Luke
Lavery is offline   Reply With Quote
Old 09-09-2005, 08:12 PM   #3
jimbobrand
Member#: 21935
2010 '13 BRZ Premium
WR Blue Pearl
I know Top_dog on here is running a set of 17"x8" or 8.5" on his RS with pretty wide tires and rolled fenders. I forgot the size but I think there is a thread here about it.
-Jim
edit: here's a link to the post I was talking about http://forums.nasioc.com/forums/show...ghlight=topdog
jimbobrand is offline   Reply With Quote
Old 09-09-2005, 08:42 PM   #4
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
1 belive 17x7.5 is the biggest you can go but you need a 215 or you will have to roll then fenders,i have 17x7 with 215's wich is a perfect combo for me
99subi is offline   Reply With Quote
Old 09-10-2005, 12:07 AM   #5
LunaticDriver
Member#: 95411
thanks for the advice i was looking into 17's with 225's so I guess ill look into gettin my fenders rolled...
Old 09-10-2005, 03:49 AM   #6
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
i have 225s on mine. on the stock 2.5rs wheel. it rubs on the strut base when cornering and when i go over bumps and stuff it rubs on the fender. BUT my 225s are taller than they should be, with a .50 ratio of sidewall to width. sooooo you should be ok if you get 225/45/16. assuming you are using 16s
svek is offline   Reply With Quote
Old 09-10-2005, 11:05 AM   #7
FriedIceCream
Member#: 84154
2010 S&M WTF
Trans Purple
since were on the subject, I have 17x8 +46 with 235/45 advan ao46's now i need tires already again now im think of switch tire size but i dont know what size to get , the advans rubbed hard core...
FriedIceCream is offline   Reply With Quote
Old 09-10-2005, 02:47 PM   #8
balajc
Member#: 15393
MY00 2.5RS Coupe 5MT
Silverthorn Metallic
I have 17x7.5 ET48 with 215/45/17 on my stock suspension RS...no rubbing
one day I would like to get some P1 wheels and 225/45/17
balajc is offline   Reply With Quote
What is the widest tire that will fit stock 07 TR Wheels RedefinedTR Tire & Wheel 11 06-30-2007 02:19 PM
What are the best tires for 06 stock 17's? brodiemash Tire & Wheel 27 05-04-2006 03:42 PM
thinkin about a 2.5rs...what are the prices on some 02,03 and 04's?? btn_turtle Alaskan Impreza Club Forum -- AKIC 46 11-17-2004 04:37 AM
what is the widest tire i should put on an 18x8 rim? JikJak Vancouver Impreza Club Forum -- VIC 7 03-26-2004 12:02 AM
17x7.5 rim, what is the widest tire i can fit on these wrxracer55 Tire & Wheel 11 11-02-2003 10:10 AM
