Old 09-09-2005, 05:09 PM   #1
saldunn83
Member#: 93018
2011 Legacy 2.5i
Caramel Bronze Pearl
Question Need help with DRL
OK, first thing first....I SEARCHED..and only found one close up pic...
I unplugged what i thought was the right one and got a CEL and no cruise control and still had DRL.....not successful
All threads I find say behind glove box...but the picture floating around here seems to show weather molding on it as if it was closer to the pass. door.
So i took 2 pictures of my car.
This is where i thought the plug was located
After that I removed the black plug which made me have to reset the ECU by disconnecting the battery to get rid of the damn CEL
What am I doing wrong guys??.....Thanks in advance
saldunn83 is offline   Reply With Quote
Old 09-09-2005, 05:17 PM   #2
gqchynaboy
Member#: 88529
It's behind the golve box on the far right side..
gqchynaboy is offline   Reply With Quote
Old 09-09-2005, 05:21 PM   #3
saldunn83
Member#: 93018
2011 Legacy 2.5i
Sooooooo........do I have to physically remove the glove box or no? If so, how?
Better yet.....where is it in regards to my pictures?
Old 09-09-2005, 05:41 PM   #4
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Some have unplugged the DRL switch without removing the glovebox. It'll require a little bit of finesse and some nimble fingers (a bit of patience helps too). It's a little more time consuming taking off the glovebox, but it's pretty easy also - just remove all of the Phillips screws (about 8-10 - can't recall for sure) and the box will come off.
Hank3 is offline   Reply With Quote
Old 09-09-2005, 08:46 PM   #5
Tim-H
Member#: 65751
'10 VULVA
Easiest way to tell, dont remove anything just look up behind the box its the only white one you can access without removing anything.
Tim-H is offline   Reply With Quote
Old 09-10-2005, 01:09 AM   #6
Homerisking
Member#: 79164
2005 WRX
tHe Silver one
Remove the glovebox...it's around 10 screws and takes ~2 minutes. Very easy, I used the same pic that Hank3 provided.
Homerisking is offline   Reply With Quote
Old 09-10-2005, 05:09 PM   #7
MGGDTW
Member#: 63464
2004 WRX
Java black pearl
You can also disconnect the DRL from under the hood. I took the whole DRL unit out.
MGGDTW is offline   Reply With Quote
Old 09-11-2005, 12:52 AM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
That is not the "whole DRL unit". It is only a dropping resistor. Removing it will disable the DRLs on stock headlights, however the main module inside the car remains active. In the event the lights are modified later, particularly if HIDs are installed, the DRL function may return. It's best to disconnect the main DRL module by the glovebox so they are gone for good.
Old 09-11-2005, 09:08 AM   #9
MGGDTW
Member#: 63464
2004 WRX
Java black pearl
Interesting...
Old 09-11-2005, 08:25 PM   #10
saldunn83
Member#: 93018
2011 Legacy 2.5i
Ok, I finally unplugged the CORRECT plug behind the glovebox and everything is all good.
Thanks guys for all the replies!
Old 09-12-2005, 11:44 AM   #11
02DaWeRXs
Member#: 95302
2002 WRX Wagon
Does anyone know what number/type of relay it is? I just hate to kepe things unplugged like that...on my e36 M3 I just exchanged the type of relay and had the choice of DRLs or no DRLs.....And I think I still have my no-DRL relay laying around somewhere...
02DaWeRXs is offline   Reply With Quote
Old 10-06-2005, 08:18 AM   #12
wagons_ho!
Member#: 16574
Are you going to remove your seatbelts too? The DRL is a proven safety feature, like seatbelts - their use is mandatory in most of Europe and Canada, and driving a car that is supposed to have DRL with them disconnected is a sizeable fine in most jurisdictions.
wagons_ho! is offline   Reply With Quote
Old 10-06-2005, 08:51 AM   #13
99ways2die
Member#: 96269
... blond with
long legs
....and who the hell will check on you daily IF your 05/06 Subaru came with them?
PS:
Never heard of anyone getting pulled over/ticketed for "no DRLs"
99ways2die is offline   Reply With Quote
Old 10-06-2005, 01:27 PM   #14
wilddave1
Member#: 9101
2005 Jeep Wrangler
Aprilia Tuono
Good info here!
wilddave1 is offline   Reply With Quote
Old 10-06-2005, 05:25 PM   #15
IIdiceII
Member#: 90438
I think the cops in newyork have bigger things to worry about. Theyre def not thinking about if people disconnected their daytime running lights.
IIdiceII is offline   Reply With Quote
Old 10-06-2005, 06:35 PM   #16
saldunn83
Member#: 93018
2011 Legacy 2.5i
That and the fact that it is not a law in the US to have DRL's
Old 10-06-2005, 09:12 PM   #17
wrb2006sti
Member#: 96895
2012 STI
Ice Silver Metallic
thanks works like a charm im so happy now i just gotta turn off the seat belt chime and im in business
wrb2006sti is offline   Reply With Quote
Old 10-09-2005, 07:03 PM   #18
Evil STI
Member#: 36792
2015 Z/28 (Vader)
Gold chains & meatballs
Oh my God! Come to think of it, I jaywalked today- twice!!!
Evil STI is offline   Reply With Quote
Old 10-09-2005, 07:46 PM   #19
sha_zapple
Member#: 41012
1998 Legacy L
DRL are for those instances where you dont need headlights, but you DO need some sort of light for other people to see you (morning fog, dawn, dusk...) If you have trouble unplugging the module, how can I expect you to remember to turn on your lights?
sha_zapple is offline   Reply With Quote
Old 10-09-2005, 09:17 PM   #20
Audi-TT
Member#: 89724
2005 WRX
Audi-TT is offline   Reply With Quote
Old 10-09-2005, 09:18 PM   #21
Audi-TT
Member#: 89724
2005 WRX
the way i did mine...i just asked Dan from harman to do it for me, and he just popped the hood and unplugged something from the actual box....dunno what he did, but hey, its all good now lol
Old 10-09-2005, 10:05 PM   #22
Manji
Member#: 89164
2002 WRX Sedan
Manji is offline   Reply With Quote
Old 10-10-2005, 01:15 AM   #23
ESEMES
Member#: 67128
2001 996TT
seal
hmmmmm..........
DO NOT unplug any yellow plugs. the black/white one is the chime.
under the driver's seat.
for show purposes only.... may void warranty and risk your health... ya know........
es
ESEMES is offline   Reply With Quote
Old 10-10-2005, 07:12 AM   #24
StealthfishWRX
Member#: 57473
04' REX (RETIRED)
I thought it was easier than that? All I had to do was unplug the silver thing in the engine bay?
StealthfishWRX is offline   Reply With Quote
Old 10-10-2005, 08:00 AM   #25
Hank3
Member#: 16157
'03 Mazda P5 <><
Lightbulb Hood vs. glovebox
The module in the engine bay is a dropping resistor, and it does not fully disable the DRL system. The plug next to the glove box is the main control module. I recommend the glovebox one just in case one ever goes to HIDs. Not unplugging the glovebox one will cause your HIDs to flicker and perhaps some other whacky things.
Need help with something truenosan Vancouver Impreza Club Forum -- VIC 7 06-02-2010 09:05 PM
Need help with DRL sti-bullet Vancouver Impreza Club Forum -- VIC 30 05-31-2009 01:40 PM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2003 12:11 PM
Going Crazy! Need Help With DRLs... GMoney Forester Forum 11 09-22-2002 11:30 AM
Help! I need help with turbo 99 HOK Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 04-16-2001 08:05 AM
