Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Old 04-22-2007, 07:44 PM   #51
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Originally Posted by lowsol94 View Post
How about 07s?? I just took out my glove box and I fail to see that plug.
The 07 DRL setup is not the same as previous years. I don't have links handy but the procedure for disabling them has been posted, here and at Scoobymods.
Old 04-23-2007, 12:47 AM   #52
EBWRC#1
Member#: 86843
Io Sono
a 500 Driver !
Can you help us out?
EBWRC#1 is offline   Reply With Quote
Old 04-23-2007, 04:19 AM   #53
WhiTe_07_WRx
Member#: 135623
2007 Subaru
I can get pics for you 07 Guys. I have done it on my 07 WRX
WhiTe_07_WRx is offline   Reply With Quote
Old 04-23-2007, 04:55 AM   #54
WhiTe_07_WRx
Member#: 135623
2007 Subaru
Alright for the 2007 WRX Owners this will only work for you. The 2007 STI is located in a Different place due to the HIDs I take it.
The Module for the 2007 WRX DRL is right next to the DP. Or Firewall on the Passenger Side. Pictures should clearly tell you what to do. I took these to help confused folks.
Here is the DRL Module for 07 WRX Owners
Here is what you need to do. Unplug and thats it. Your good to go. No more DRL.
Old 04-27-2007, 05:43 AM   #55
STitrojan
Member#: 145583
06 WRX STi
hey guys how about unplugging the DRL's for an 06 sti anybody got pics?? thanks for the help.
STitrojan is offline   Reply With Quote
Old 04-28-2007, 08:51 PM   #56
rekd0514
Member#: 147130
Wow, removing some of the electical annoyances in the Subarus is as easy as unpluging it. I am impressed!
rekd0514 is offline   Reply With Quote
Old 04-29-2007, 09:57 PM   #57
geddesk2
Member#: 119397
98 L & RS
Red L, RBP RS!
Originally Posted by ESEMES View Post
hmmmmm..........
DO NOT unplug any yellow plugs. the black/white one is the chime.
under the driver's seat.
for show purposes only.... may void warranty and risk your health... ya know........
es
Does that white plug only control the chime???????
I unplugged it....but I want to make sure my airbags will still work!!
geddesk2 is offline   Reply With Quote
Old 04-30-2007, 05:17 AM   #58
WhiTe_07_WRx
Member#: 135623
2007 Subaru
there is a seatbelt trick u do to stop the chime instead of doing that.
Old 04-30-2007, 03:18 PM   #59
geddesk2
Member#: 119397
98 L & RS
Red L, RBP RS!
Yes I know that, but unplugging the harness doesn't reset like the seatbelt trick when you unplug the battery
Old 07-14-2007, 12:19 PM   #60
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
OK, so we all know how to disable the 02-07 WRX DRL. CAn somebody lend a hand to us 07 STI w/ HID? We also would like to disable our DRL.
cpunlamd is offline   Reply With Quote
Old 07-16-2007, 06:51 PM   #61
Jonny07subie
Member#: 152231
07 Impreza 2.5i
how would you disable the DRL in a 07 2.5i if its different than the 07 wrx??
Jonny07subie is offline   Reply With Quote
Old 07-16-2007, 07:22 PM   #62
TheSilverFox
Member#: 142520
2006 STI - Protuned
308whp - SilverFox
anyone have some detailed pics of where the DRL switch is to unplug on a 2006 STI??? the pics on this thread are old. Any help with pictures would be greatly appreciated.
--J
TheSilverFox is offline   Reply With Quote
Old 07-16-2007, 08:42 PM   #63
2007_2.5i
Member#: 146644
2007 Sedan 2.5i 5MT
CGM
Lightbulb
The photos and description in WhiTe_07_WRx's post about disconnecting the module under the hood is NOT THE BEST WAY! There is an appropriate wire behind the glovebox for '06/'07s, and a good thread with pictures. It is simply the process of disconnecting a different plug and removing one single pin from it. Here we go:
Quote from Mulder: "Note that, as with the earlier years with DRLs, the "module" in the engine bay is NOT the actual DRL control unit. It is merely the dropping resistor that provides the ground connection when the DRLs are active. Disconnecting it will keep the DRLs off as long as you have the stock headlights, however the DRL system remains electrically active and there will be voltage at the headlights and on that connector. In the event you install HIDs later or otherwise modify your lights so there is an alternate ground path, the DRL function will return. To completely disable the DRLs with no chance of having them return, the main module must be disconnected as described in the links above."
THIS IS THE LINK!!! POST #49!!!
http://forums.nasioc.com/forums/show...1119031&page=2
I did this on my '07 2.5i, which has the same, non-HID headlights as many WRXs and WRX TRs.
2007_2.5i is offline   Reply With Quote
Old 09-01-2007, 05:24 PM   #64
B Foxy
Member#: 127242
2004 WRX
Just used this method for my 04 wrx and it worked like a charm... I took off the glove box just to make sure I was unplugging the right wire... Thanks a lot! Now I just gotta figure out how to run with only my fog lights.... Im sure I've seen that around here somewhere.
B Foxy is offline   Reply With Quote
Old 09-09-2007, 11:36 AM   #65
snowdrift06
Member#: 158604
easy enough.. used the glovebox method on my 06, maybe 8 screws and a clip. 5 minutes w/ piss break
i suggest doing it this way to avoid exposed wires under the hood
snowdrift06 is offline   Reply With Quote
Old 09-16-2007, 10:39 PM   #66
b0nd18t
Member#: 155876
2007 STI
Blouch Dom3
hmmmmm..........
es
there are two metal ends that are rather securely connected in the white plug, what did u do to get those off without damage?? oh and any pics/descriptions for 07 sti to unplug DRL? btw, my DRL's seem to not ALWAYS be on, sometimes i have control and sometimes they are just on, what gives !
b0nd18t is offline   Reply With Quote
Old 09-27-2007, 01:51 AM   #67
thejaredhuang
Member#: 86206
2006 WRX Wagon
Just FYI, its not by the firewall, its aft a little hidden by the glovebox if you don't remove it. I initially took the green one out by mistake.
thejaredhuang is offline   Reply With Quote
Old 10-12-2007, 12:11 AM   #68
1bugeyedrex
Member#: 145684
06 WRX STi
White/Gold
Originally Posted by 2bluewagons View Post
I have been looking for a better comprimise of safety and bulb life for the DRL thing, and may have found it over at scoobymods (don't have the link just now).
Put a switch in line with the resistor in the engine bay (or the module behind the GB if I knew which wire is which) so I can choose when to have DRL's on. Sometimes it useful at night to be able to kill the lights completely without pulling up on the e-brake a notch.
I agree that DRL's are a good safety measure, but really I would just prefer to have a switch for everything my car does...
I like the sound of this, how would I acutally wire something like this up? thanks.
1bugeyedrex is offline   Reply With Quote
Old 12-13-2007, 10:59 PM   #69
STi_q8
Member#: 157696
07 Impreza WRX STI
Originally Posted by MindzeyeWRX02 View Post
FOUND IT!!
Thanks for the help. LOL. With the info on this thread and taking out the glovebox (which made it a whole lot easier to figure out what plug was the DRL), I finally got it. next light mod, the fog lights.
Thanks anyhow.
Dude got pics? i cant find it... was tryin to do it for a friend...
thanks
STi_q8 is offline   Reply With Quote
Old 12-15-2007, 12:43 AM   #70
ringe
Member#: 49998
2007 WRX CT Stg 2
Originally Posted by wagons_ho! View Post
Are you going to remove your seatbelts too? The DRL is a proven safety feature, like seatbelts - their use is mandatory in most of Europe and Canada, and driving a car that is supposed to have DRL with them disconnected is a sizeable fine in most jurisdictions.
DRLs are actually a dubious safety feature, and if you like to upgrade your bulbs or convert to xenon HIDs for truly safer night driving, the DRL function either interferes with correct function or burns out your pricey 65watt bulbs...so away with DRLs.
ringe is offline   Reply With Quote
Old 12-18-2007, 12:57 PM   #71
geddesk2
Member#: 119397
98 L & RS
Red L, RBP RS!
I unplugged the grey plug under the hood and have been driving for 8 months w/o an issue.
Old 12-20-2007, 03:28 PM   #72
pDubs
Member#: 149317
'95 BMW M3 (E36)
'05 Kawi ZX6R, '73 CB350F
Originally Posted by StealthfishWRX View Post
I thought it was easier than that? All I had to do was unplug the silver thing in the engine bay?
+1. I unpluged the thing in the engine bay and it worked perfectly
pDubs is offline   Reply With Quote
Old 12-20-2007, 05:41 PM   #73
stu1811
Member#: 124651
2011 LGT
hmmmmm..........
es
Ever better method that doesnt require unplugging anything...
Sit in driver seat
Put key in on position
In 20-30 sec click and unclick the seat belt 30 times
Works until you reset the ecu
stu1811 is offline   Reply With Quote
Old 05-13-2008, 10:39 AM   #74
AaronCompNetSys
Member#: 144848
05 WRX, 05 Saabaru
01 S2K, 91 Impulse RS
[Posted for archive purposes]
Located behind the glove box, about the same place as a seated passenger's right knee.
DRL connector module in the glove box on 2004 2005 04 05 Impreza WRX Daytime running lights
AaronCompNetSys is offline   Reply With Quote
Old 06-09-2008, 07:53 PM   #75
Spore
Member#: 100117
2009 Impreza 2.5i
Satin White Pearl
Originally Posted by AaronCompNetSys View Post
First, I would like to apologize for ressurecting another dead thread regarding DRL. I just did my DRL delete, but instead of the indicated plug, I disconnect the black plug beside the blue one. It seemed to work for me. Will there be any negative effects from doing that?
Spore is offline   Reply With Quote
Need help with something truenosan Vancouver Impreza Club Forum -- VIC 7 06-02-2010 09:05 PM
Need help with DRL sti-bullet Vancouver Impreza Club Forum -- VIC 30 05-31-2009 01:40 PM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2003 12:11 PM
Going Crazy! Need Help With DRLs... GMoney Forester Forum 11 09-22-2002 11:30 AM
Help! I need help with turbo 99 HOK Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 04-16-2001 08:05 AM
