Old 04-05-2010, 03:14 AM   #101
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
From left to right those relays are the fuel pump relay, main relay, and throttle control relay. The DLR relay should be just to the right of those, perhaps under the dash, along with the high beam relay. They may be the ones shown in the bottom right side of your picture.
Old 06-16-2010, 06:10 AM   #102
bilzer07
Member#: 249241
2007 Impreza 2.5
Gray
Default Disable DRL on 07 IMpreza
I am trying to find out how to disable the DRL on 07 Impreza NON TURBO. This is the 2.5. I have seen a few posts in regards to the HID lights and I have a basic model. Can someone lead me to how to accomplish this?
bilzer07 is offline   Reply With Quote
Old 06-17-2010, 11:16 AM   #103
chuds
Member#: 245141
07 2.5i
cgm
I have the same car this is how I did mine.
http://forums.nasioc.com/forums/show...8&postcount=49
Remove glove box
Disconnect the BLACK relay
Remove center wire (yellow w/ red stripe)
Tape the bare connection and tuck it away
Connect relay back up then glove box
done
Forgot to add this is a good time to check you cabin air filter
Its in the white box in the 1st picture
chuds is offline   Reply With Quote
Old 06-07-2011, 06:56 PM   #104
PWR_Slave
Member#: 46007
2002 WRX Wag MBP
Default with PIX
RISE FROM YOUR GRAVE!
Due to the age of this thread (and that I spent too long to admit on here getting thus done), here's the pic.
[IMG][/IMG]
PWR_Slave is offline   Reply With Quote
Old 06-25-2011, 06:16 PM   #105
kcle730
Member#: 266918
2007 Impreza WRX STi
So itz not really visible? itz hidden behind the black thing?
kcle730 is offline   Reply With Quote
Old 06-27-2011, 04:55 AM   #106
Subarulou1
Member#: 286763
I did this and now my airbag light is off, but I still managed to disable my DRL's. Any help with the airbag light? Thanx
Subarulou1 is offline   Reply With Quote
Old 06-27-2011, 04:56 AM   #107
Subarulou1
Member#: 286763
^^. I mean my airbag light turned on**. Haha
Old 06-27-2011, 10:52 AM   #108
Cougar4
Member#: 53443
Winestone
You may have disturbed a connection to the passenger side airbag. I recommend you check the connection.
Old 06-27-2011, 04:22 PM   #109
Subarulou1
Member#: 286763
Ok....Thanx cougar4
Old 10-06-2011, 08:11 PM   #110
Subiedude324
Member#: 285665
2007 Wrx STI
I have a 2007 Sti and i need help disconnecting my drl's. I disconnected what I believe is the drl module behind the glove box but that had no affect. Does anyone know what I have to do exactly for the 07 Sti?
Subiedude324 is offline   Reply With Quote
Old 10-09-2011, 04:02 PM   #111
SubiRexWagon
Member#: 273393
2011 WRX 5-door
If what you unplugged was a 10pin connector that was all yellow on color you have unplugged one of the SRS connections, plug that back in and look for the other one.
SubiRexWagon is offline   Reply With Quote
Old 10-09-2011, 06:04 PM   #112
Tim915
Member#: 185624
To turn my DRL's off in my 02 Impreza.
I disconnected the plug in the engine bay area, top left side.
Seems much simpler than this anyways.
Tim915 is offline   Reply With Quote
Old 10-09-2011, 07:11 PM   #113
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Go back in this thread and read post #9 please.
Old 03-01-2013, 09:44 AM   #114
Culti
Member#: 248192
2007 STi
Default Dealership
Hey guys, this may have bee answered but someone was saying something about problems with the law? If I were to do this mod and take it to the dealer for service would they make a fuss and charge me? Thanks.
Culti is offline   Reply With Quote
Old 03-01-2013, 10:05 AM   #115
wlit
Member#: 157385
2007 Impreza WRX
Urban Gray Metallic
It should not, I have it disable for 3 years and no complain what so ever from dealership. Check with state inspection requirement and see if DRL is require in your state.
wlit is offline   Reply With Quote
Old 03-15-2013, 10:57 PM   #116
trademyexhaustforurs
Member#: 350337
Woah thanks so much hate daytime running lights, this thread was so helpful
trademyexhaustforurs is offline   Reply With Quote
Need help with something truenosan Vancouver Impreza Club Forum -- VIC 7 06-02-2010 09:05 PM
Need help with DRL sti-bullet Vancouver Impreza Club Forum -- VIC 30 05-31-2009 01:40 PM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain 7 04-18-2003 12:11 PM
Going Crazy! Need Help With DRLs... GMoney Forester Forum 11 09-22-2002 11:30 AM
Help! I need help with turbo 99 HOK Factory 2.0L Turbo Powertrain 20 04-16-2001 08:05 AM
Message Board Statistics All times are GMT -4. The time now is 12:37 AM.
