Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 09-09-2005, 08:27 PM   #1
Panic
Member#: 48699
2008 Evo X GSR
Apex Silver
Default v7 or v8 STi Splitter WRX Intercooler Shroud
Basically, I have an STi scoop on my 04 and am currently using the inadequate wrx splitter and the stock wrx intercooler. What I want to know is whether I can use the v7 or v8 splitter with my wrx shroud and intercooler and get a good seal...
Thanks in advance.
Panic is offline   Reply With Quote
Old 09-09-2005, 08:39 PM   #2
KingOfSiam
Member#: 84636
2005 WRX (automatic)
Crystal Gray
sweet question. I also need to know what equipment to add plus the actual scoop.
KingOfSiam is offline   Reply With Quote
Old 09-10-2005, 01:58 AM   #3
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
No.
Both Sti splitters are larger on the bottom for the larger IC.So no your stock shroud(bellows) will not go on there. Just modify your stock duct to take advantage of the taller scoop and add your own splitter blade in there.
Did you know that the 04/05's already have a stock scoop just as tall as the v7 Sti's?
GDR is offline   Reply With Quote
Old 09-10-2005, 02:55 AM   #4
shinsain
Member#: 51745
LIKE A
BOSS
Thanks in advance.
Use the V7 splitter/bellows w/ the stock intercooler. Does the V7 splitter not come w/ a divider like the V8?
Either that, or buy an STI intercooler to fit the V8 splitter/bellows and take advantage of it all.
Just modifying your stock scoop can be a pita, but it can work. Not as well as an STI splitter/bellows IMO, but it will work.
At any rate, the stock scoop/splitter, etc. is more than adequate for your stock intercooler. If you're running the stock intercooler w/ just an STI scoop, you're just as well off leaving the splitter/bellows on there anyway until you go to a bigger I/C.
Aaron
shinsain is offline   Reply With Quote
v7 or v8 Sti intercooler fitment on EJ20G? possible? scobaru Subaru Conversions 6 03-27-2005 03:26 PM
will a new v7 or v8 give the wrx more torque? toebotypera Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-22-2005 01:26 AM
v7 or v8 STI upgrade for a wagon evil girl General Community 15 03-21-2005 04:46 PM
needed: Stock V7 or V8 STi Dyno Plot Hokie Guy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-09-2005 11:28 AM
Who has popped a v7 or v8 STI JDM shortblock and why? jblaine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-20-2004 04:57 PM
