Old 09-10-2005, 12:14 AM   #1
Mike1967
Member#: 87762
Default Checking re-using Timing Belt Tensioner
I just replaced my head gaskets and had my heads resurfaced.
I am now putting everything back together and have a question on wether or not I need to replace my tensioner pulley
The pulley has less than 10K miles on it because the timing belt and water pump were just recently replaced. I went ahead and replaced the pulley at the time that I replaced the belt because the dealer scared me by telling me I had to use a verticle press.
I compressed the current tensioner with a C-Clamp and held it in place with a small screwdriver.
But when I install it and pull the pin there is not movement the position of the tension shaft. In otherwords, I can re-insert the screwdrive through the shaft so the shaft position has not changed.
The last time I did this I clearly remember the tension shaft moving when I pulled the pin.
However, when I started to take the belt back off....the tensioner shaft fully extended as soon as I released the tension on the belt. And I was also unable to push the shaft in by hand...so there is obviously tension in the shaft. I also cannot see any evidence of a leak around the shaft seal.
How do I know if the tensioner is working ? Can you measure deflection on the timing belt ?
Thanks in advance !!!!
Mike1967 is offline   Reply With Quote
TWO timing Belt Tensioners-One Used, One New Audioexcels Engine/Power/Exhaust 33 09-27-2010 10:00 PM
FS:Brand New OEM Timing Belt Tensioner & Timing Belt jsnm Engine/Power/Exhaust 5 04-06-2010 12:58 PM
Used Parts / yard sale: Prodrive EBCS, ej257, timing belt tensioner and Water Pump @@ IA Performance Engine/Power/Exhaust 1 08-03-2009 11:13 AM
FS: Used STi Pistons, Timing Belt Tensioner, Various STi Engine Gaskets and seals,... fattie92 MWSOC Private Classifieds 2 05-10-2009 10:18 PM
FS: used timing belt/water pump/tensioner from 02 WRX (NY) txl146 Engine/Power/Exhaust 0 03-23-2009 05:02 PM
