Old 09-10-2005, 09:51 AM   #1
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
Default ok so i searched, wrx injectors in my00 fuel rail? need adapter?
i was reading phatsuby had these in his car, i need some bigger injectors, but i also read that i would need an adapter to fit these, i cant find rc injectors so i was wondering about these?
G
GregBolby is offline   Reply With Quote
Old 09-10-2005, 11:35 AM   #2
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Apparently that's the solution if you didn't need a lot more fuel - WRX injectors are dime a dozen and I believe that RalliTEK has been selling an adapter for these. Now granted another solution nowadays for RS-T to get more fuel is to weld an extra injector around the TB and have your EM do stagged injection
kgb is offline   Reply With Quote
Old 09-10-2005, 11:37 AM   #3
Tats
Member#: 5692
WTF? YES! I am
better than you!
IIRC..if you mod the WRX injectors they can flow about 700cc. ( A LOT more fuel)
Tats is offline   Reply With Quote
Old 09-10-2005, 01:04 PM   #4
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Would the flow pattern be affected? I have 2 options - Delphi injectors from racetronix.com, or WRX injectors with adapters (unmodded is 420, modded is 700 as you claim). Stupid Air Assist manifold...
Old 09-11-2005, 12:54 AM   #5
redwagon
Member#: 2181
2008 SpecB
*cough* '99 intake manifold *cough*
redwagon is offline   Reply With Quote
Old 09-12-2005, 12:43 AM   #6
balisticmotors
Member#: 81966
what is diffrent on the 99 manilfold
balisticmotors is offline   Reply With Quote
Old 09-12-2005, 01:36 AM   #7
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
No air assist, but no MAP sensor either...
Old 09-12-2005, 04:29 AM   #8
redwagon
Member#: 2181
2008 SpecB
^^^ That's right. No air assist, bosses for far more common injectors. The boss for the MAP sensor is there, it just needs facing and three holes drilled, two tapped. Anyone with a Bridgeport will do it for you in five minutes. Much easier than kludging fuel rails.
Injectors in Perrin fuel rails tight fit e-zee Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-21-2009 06:25 PM
Do I need a WRX Fuel rail to run WRX injectors in an RS-T? Tattoo Collector Normally Aspirated with bolt-on Forced Induction Powertrain 10 01-14-2006 09:06 AM
stock injectors in perrin fuel rails??????? jared nelson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-13-2005 09:39 PM
stock wrx injectors and fuel rail needed Cxha00RS Private Vehicle 'For Sale' Classifieds 0 06-24-2004 03:45 AM
how to get wrx injectors to seal in EJ25 fuel rail? PHATsuby Normally Aspirated with bolt-on Forced Induction Powertrain 10 08-01-2003 12:41 AM
