#1 |
Member#: 1366
VIC
Vehicle:2000 RS-T -> RSTi-8 Blue Ridge Pearl |
Or it entirely depends on the block? I have never heard knock or detonation before and without an aftermarket knock sensor, what is the best environment to do tuning under so that I can actually hear it over the turbo and the exhaust? Will I instinctively know that the engine knocked? The other way is to hook up an SSM-based scanner thru the OBD-II port and read the knock counters off the stock ECU but I don't have one...
Thanks for the help.
#2 |
Member#: 82612
Vehicle:'02 WRX - Sold Now 2013 WRX |
You should be able to hear it! It sounds like a thump on your engine as if someone hit it with a hammer.
Remember though, these engines produce somewhat high knock READINGS. What may seem like knock based on reading values, may not really be knock. If you can get access to a datalogger that reads knock values, not so much knock COUNT, that is very helpful. A big step in a knock reading is usually knock. I get knock readings all the way up to 80 or so but its a smooth transition all the way up there so it's safe. |
#3 |
Member#: 77483
NWIC
Vehicle:2009 Audi A3 2.0T q Lava Grey |
At high RPMs it can sound like BBs rattling in a can.
#4 |
Member#: 1366
VIC
Hmm... that sounds like it will be tough to spot - I don't really have tools have read the factory knock sensor (ie SSM scanner).
#5 |
Member#: 37938
Vehicle:02 WRX Blue Mica |
#6 |
Member#: 84181
NESIC
Vehicle:NASA #530 PTC |
uggg, if you have exhaust, you prolly cant hear jack up on the highway unless its BAD - if you got some engine management i know the utech flashes the CEL when theres knock
#7 | |
Member#: 56468
NWIC
Vehicle:04 Improved STI Dirty White |
#8 | |
Member#: 1366
VIC
#9 |
Member#: 69435
Vehicle:2005 Aspen STi,rip02 Bugeye mafia 02 :( |
its all that crackeling in the whole clip
#10 |
Member#: 48594
Vehicle:1997 us2.5L ver3 sti white |
Any small audio amp and some headphones connected to a knocksensor on the engine will work fine.
I use this very cheap .5Watt amp powered by a 9volt battery with some headhpones and it sound just like that that sound clip above. It sounds like someone flicking the back of the headphones. http://www.dse.co.nz/cgi-bin/dse.sto...uct/View/K5604 |
#11 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
it's generally a sharp click or snap. in the above clip on my website (which originally came from turboxs btw) it starts about halfway through and knocks a LOT. if your engine management is doing its job wrt knock detection you will hear ONE click and that's it...i know that's exactly what my utec does.
ken |
#12 | |
Member#: 37938
Ride5000 ... would you please share your Utec knock treshold numbers? Thanks a lot ... ![]() |
#13 | |
Member#: 37938
you are right, knock happened in the middle of the clip. Last edited by WRX-Blue-Mica; 09-17-2005 at 04:16 AM. |
#14 |
Member#: 1366
VIC
So technically you can just tap off the stock Knock sensor, put it through an amp and hear it yourself?
#15 | |
Member#: 77483
NWIC
I'd never heard it that bad, scared the **** out of me. |
#16 | |
Member#: 32792
NESIC
115 110 105 101 95 84 75 70 iirc they're all about +5 over default values. i pull 1.5 degrees on a 2 count of knock, max of 15 degrees pulled, duration 100 crank cycles. hth ken |
#17 |
Member#: 90017
Vehicle:2003 Forester 2.5X WRC Wim-Wam Shaft |
If you feel so inclined, you could always buy or borrow a Tactrix cable and use Tari DL1 to do logging. You would need a laptop, and obviously you couldn't plug anything else into the OBD2 port while using it. That solution would set you back $70, but if you're worried about not hearing the knock it's an option.
#18 |
Member#: 1366
VIC
Is this an SSM solution? OBD-II can't read the knock sensor right?
#19 | |
Member#: 90017
#20 |
Member#: 7962
Vehicle:05' V35 Skyline PSM 02WRX -SOLD |
Anyone have any fresh ideas on this??
A guy from Indianapolis had a simple setup where he wired his knock sensor to his stereo on a switch, then he just turned up the radio!!!! Anyone know how to do this????? Thanks!! We could all use a knock radio! |
#21 |
Member#: 140643
South East
Vehicle:04' PSM Limited Wrx 371whp/344wtq E85 |
i'm gonna give this a shot: http://www.d-series.org/forums/diy-f...5-dollars.html
#22 |
Member#: 26568
NESIC
Vehicle:2003 Yellow Bugeye Version 8-Vf37 |
^^^ i've made one of those setups. It gets really loud, especially under wot. There is so much going on that for me, its hard to differentiate what is valve noise, what is piston noise. Can't say i've ever heard knock using them, but i've only used them about 4-5 times since i've made it.
#23 | |
Member#: 32792
NESIC
according to txs, the tuner pro does employ a high pass filter to help differentiate the racket. it also uses a real knock sensor bolted to the block. i can say that through the HPF of the tuner pro, knock sounds like a sharp crack. above 4k rpms or so things do get pretty noisy, so you have to listen closely. although i have a cassette tape adapter hooked up, the best way to monitor, especially when setting thresholds, is through headphones. |
| Thread Tools | |
| Display Modes | |
| any one know what size threads the head bolts are on a EJ motor | mellow65 | North West Impreza Club Forum -- NWIC | 2 | 11-01-2007 04:49 PM |
| What does knock sound like? | bdon22 | Newbies & FAQs | 5 | 03-03-2007 06:58 AM |
| anyone have a sound clip of the spt cat back on an STI? | wrb2006sti | Factory 2.5L Turbo Powertrain | 3 | 05-12-2006 01:36 AM |
| Knock noise comming from front of engine(maybe starter?sounds like card in propeller | AustinSTi | Normally Aspirated Powertrain | 2 | 06-28-2005 05:41 PM |
| What does ping and knock sound like? | edkwon | Normally Aspirated Powertrain | 6 | 04-08-2003 05:00 PM |
