Old 09-10-2005, 07:08 PM   #1
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Default ECU and smog equipment re-learn
Aight! No time to search on this one. My 99 LW has been sitting since the 1st of June and I disconnected the battery to keep it from running down. Anyway, I hooked everything back up because I'm registering it and needed to take it in for smog.
Car started right up with no problems but I only drove it about 4-5 miles to the shop to get it smogged. When they ran the test the car passed all of the "sniff" stuff but the cats and O2 sensors wouldn't read. The guy asked me straight away if I had disconnected the battery and I said yes. He then told me that the car needed some run-time for the ECU to gather data and do its own self-test.
My question to all of you is, how many start-run cycles do I have to do before the car's ECU captures this info? I know it all works, or it wouldn't have passed the tailpipe test. It's just that ECU doesn't have the info in its memory yet. As is, I'm in a failed status until this is resolved.
I knew I should have taken it out and driven it this week. Sometimes, you got to listed to the little voice inside your head...
Anyway, TIA and I appreciate your thoughts/experiences on this one.
Dale
Subietonic is offline   Reply With Quote
Old 09-10-2005, 07:16 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
I usually notice that it takes 2-3 tanks to "normalize" the maps after an ecu reset.
I seem to think the first tank runs really rich(less mpg at least)...and then it starts to normalize after that.
fibuz
fibuz is offline   Reply With Quote
Old 09-10-2005, 08:35 PM   #3
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
Legacy
Yea thats what i experienced after my ECU reset, rich in the begininning but then it calmed down and by the 2nd tank full in it, it was running they way it should. I dont think it would have passed the tail pipe test, mine was running rich enough to smell it at the back on idle.
Kawikid20o2 is offline   Reply With Quote
Old 09-10-2005, 11:06 PM   #4
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Car runs absolutely perfectly, it's just that the ECU has to self-test other components to ensure that they're on-line and ready to go as apposed to running different fuel maps and passed the sniff test with flying colors.
Apparently, the ECU needs several cycles to pickup and store in memory that these components are on-line and working. I ran it for about 30 miles at highway speeds after the test but this still may not be enough to register. The 4-5 miles to the smog shop were all surface streets and 30 mph or less. It got into the normal operating temp without any problem but I don't think the cats got hot enough is the problem.
Dale
Old 09-11-2005, 12:52 AM   #5
KD7000
Member#: 16653
2012 Mazda 3
2004 Honda Pilot
here ya go:
Originally Posted by North Ursalia (from another ECU thread)
It's 100 miles (usually) on a Subaru ECU before it changes to "ready" from "cleared".
KD7000 is offline   Reply With Quote
Old 09-11-2005, 06:13 AM   #6
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Great! That's what I was looking for. I'll have to run it some more tomorrow to get it back up to "ready". Ticks me off that I didn't think of this when I had the battery disconnected all that time. I could have just put a trickle charger on it and none of this would be an issue. Will cost me another $30.00 on top of the $45.00 I paid today for the test. Oh well, live and learn.
Thanks all,
Dale
Old 09-11-2005, 06:58 PM   #7
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
good luck hope it passes!
Best way to re-learn after ECU reset? 1DOWNCLOWN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-10-2004 04:09 PM
shat exactly is the 'vishnu method' for re-learning the ECU ? SportyBry STi Forum Archive 2 08-18-2003 04:13 PM
change in altitude, will the ECU re-learn? philip_g Engine Management & Tuning 19 05-24-2003 02:04 PM
Stock ECU re-learning question! Bobsterwrx Engine Management & Tuning 3 11-14-2002 09:10 PM
ECU re-learning RezaREX Service & Maintenance 6 08-15-2002 11:34 PM
