Old 09-11-2005, 08:49 AM   #1
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
Default Anyone here running a Deadbolt Monster TD04
If so, what's your feedback? Did you really notice a signifigant difference? Dyno's and butt dynos appreciated.
ScoobyNubieToo! is offline   Reply With Quote
Old 09-11-2005, 11:23 AM   #2
wrxwagon05
Member#: 72407
2005 WRX Wagon
WR Blue
wrxwagon05 is offline   Reply With Quote
Old 09-11-2005, 01:01 PM   #3
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
Thanx 4 the typical "Do a search" answer but I'm trying to get more than one opinion. But I do appreciate the link....the dyno graph was nice. Anyone else got one?
Old 09-11-2005, 05:09 PM   #4
Bundyboyz
Member#: 32764
2003 WRX with 91K
New Motor & Paint WRB
I considered one pretty heavily until I did a search... mine as well save up for a VF series... as the benefits are nothing you can feel on the butt dyno.
Bundyboyz is offline   Reply With Quote
Old 09-11-2005, 07:27 PM   #5
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
I called Jerry @ DB about one and he said at my whp level it really wouldnt be worth doing. And its not like 232whp is really high!
BVM is offline   Reply With Quote
Old 09-11-2005, 07:34 PM   #6
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
My understanding is that it's a good holdover until you can afford to go the whole VF, injector, fuel pump upgrade.
Old 09-11-2005, 11:22 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
BULLSPIT.
Old 09-11-2005, 11:26 PM   #8
REX8
Member#: 24038
Originally Posted by Uncle Scotty
BULLSPIT.
Scotty,
How do you feel about running one on stock EM, or an untuned stage II? Can we still get a nasioc deal? I thought I remembered $200 + sending in our old turbo.
Old 09-11-2005, 11:44 PM   #9
peterex
Member#: 27021
2015 WRX
I ran it on a Cobb basemap, and then had it Protuned. Gains were there in either situation, but more noticeable on the custom tune (obviously).
Benefits:
-quicker spool
-quicker turbo response from a roll
-smoother part throttle boost delivery
-slight power increase
Don't expect a "holy ****" kind of difference - you'd probably need a 16g or something for that. But, if you want to stay with the stock turbo, I'd consider it a worthwhile mod. I'm not sure I'd shell out the bucks to get one new, however. Buy it used or have an experienced local port it for you. I'm happy with mine, but I am realistic that it is more of a driveability mod than a power mod.
peterex is offline   Reply With Quote
Old 09-12-2005, 12:31 AM   #10
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
Benefits:
-quicker spool
I'm thinking of doing this as a holdover. I'm still under my factory warranty and I'm kinda thinking that the Deadbolt TD04 might fly under the radar with the dealer.
Old 09-12-2005, 12:59 AM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by REX8
Scotty,
....untuned isn't nearly as good as tuned....I played with my tune using my UTEC and it was GREAT...the car literally drove like a small NA v8 under the hood..the boost gauge needle would move so fast that it was
....but unless you go to extraordinary measures, you will not see more than ~220-230WHP
Old 09-12-2005, 10:46 AM   #12
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Based on everything read on this board, you will achieve a noticeable difference in the bottom end of the performance spectrum (more low-end torque), but don't expect much, if any, HP gains. You are not changing the turbo size, just the internal air flow characteristics into and out of the turbo unit.
But, would you rather spend now for a "holdover" or save your money for a new, larger turbo in a little while, if you are considering going to a larger turbo.
And if you talk to [email protected], he recommends larger injectors, pump and EM w/the Monster TD04. So, it will be more than just money for the ported TD04, if you want to do it right.
Samurai Jack is offline   Reply With Quote
Old 09-12-2005, 01:12 PM   #13
phamster
Member#: 59291
the phamster had one and i eventually went and installed a small 16G from deadbolt. once you start modding, you just want more, so what is your goal?
i had one on a cobb stage 2 set up..
like somebody else stated, it is really a driveability mod than a power mod... i had noticed, is first and second gear is awesome, but anymore from that it is just like stock.. power is quick but it isnt anymore power.. just faster...so the area under the curve on the left side is just greater..
so depends on what you want..
phamster
phamster is offline   Reply With Quote
Old 09-12-2005, 07:21 PM   #14
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
phamster
As previously stated....I'm only thinking about this to fly under the radar with the dealer. I've already got the Cobb AP and StreetTuner. I don't understand why you would need larger injectors for the Monster TD04 I mean it's basically a P+P stock turbo? The low end spool up would keep me happy for a while until warranty is up in 1 1/2 years.
Old 09-12-2005, 08:23 PM   #15
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
I have one. I went stage2 the same time I got the P&P so it's hard to tell. what I can tell you is that my current setup continues to pull well past redline. I consider myself fairly conservative and I don't even like to hit redline (shifting a little before even under the hardest accelleration) but there have been a couple of time that it gets away from my and I don't realize that I've hit, well, way above. The local tuner says that the ported turbos tend to hold boost up top better.
However, if I had it to do over again, I'd probably go VF35.
I hope this helps.
HerculesPeanut is offline   Reply With Quote
Old 09-12-2005, 11:39 PM   #16
peterex
Member#: 27021
2015 WRX
IIRC P&P stockers do flow a *bit* more air - hence the suggestion of larger injectors. But you can go about it other ways as well. You can throw in a Walbro and do the FPR mod, which would basically give you the flow of 550s for 1/4th the cost. As for me, I just threw in a Walbro (lowered IDCs about 5%) and had it tuned. I'm not really worried - my tuner left me enough headroom without giving up too much performance. If you just throw the Deadbolt on without injectors/fuel pump, your injectors will only come close to going static when it is cold outside, so you could always turn the boost down a bit.
A lot of people will say that you're wasting your time with a modified stock turbo, but keep in mind that your internals are under less stress at 230+ whp (with more low end) than they are at the 260+ whp of an IHI turbo. I haven't seen too many people on TD04s losing compression... Anyway, it's not always about ultimate power. Some people want a bit more power/driveability without the gearbox/engine issues that start to pop up more frequently as one nears 300 whp.
Old 09-13-2005, 05:39 AM   #17
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
No one should need more few with a P&P stock turbo. I'm arguably the hottest stock turbo'd car in the nation and my IDCs are fine. I guess it depends on your tuner though.
I also agree with peterex about driveability and reliability. With my setup, I have less HP then many aftermarket turbos. BUT, with my torque curve thanks to the P&P turbo and the tune, I have MANY aftermarket turbo people. 250 ft/lbs of torque at 3000 RPM is NO JOKE.
Old 09-13-2005, 06:45 AM   #18
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
Sounds nice, UNA! I might go that route until my warranty is up then I think it's gonna be a Super16G 4 me!
Old 09-14-2005, 09:16 PM   #19
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
I think I'm gonna pick up a POS TD04 and get it converted to a Monster!
Old 09-14-2005, 09:38 PM   #20
peterex
Member#: 27021
2015 WRX
A bit off topic, but I have a borked TD04 for sale if you are interested. The exhaust housing and turbine housing are currently split, so you could always send the whole thing to Deadbolt and get it rebuilt/ported (probably just needs a new bearing). Or, even easier than that, you can port the exhaust housing yourself and swap it onto the turbo you have right now. PM if interested.
Old 09-14-2005, 09:41 PM   #21
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
WOuld deadbolt even deem that as rebuildable?
Old 09-14-2005, 10:17 PM   #22
peterex
Member#: 27021
2015 WRX
Of course they would. Look under your hood at your stock turbo. There is a ring clamp that holds the exhaust housing to the turbine housing. In fact, in order to port or rebuild your turbo, the two halves must be separated anyway. As for the bearing, as I understand it, that is a routine part of any turbo rebuild.
You could always PM Jerry at Deadbolt and ask him to be 100% sure.
Old 09-14-2005, 10:27 PM   #23
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
Thumbs up
Just asking...PM me a price shipped to 08034 business address.
Old 09-15-2005, 09:30 AM   #24
Bundyboyz
Member#: 32764
2003 WRX with 91K
Without engine management is what I meant.
Old 09-15-2005, 01:33 PM   #25
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
I'm running a Deadbolt TD04 with Cobb's Stage 2. Here's my dyno sheet:
Hank3 is offline   Reply With Quote
deadbolt monster TD04 or BLOUCH 19t td04 for 2.0 wrx moorebl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 76 10-19-2010 06:11 PM
WTB: Deadbolt monster td04 or Blouch td04 Kannekt Private 'Wanted' Classifieds 8 09-23-2010 03:08 AM
WTB: Deadbolt monster td04 or Blouch td04 Kannekt Tri-State Area Private Classifieds 7 04-29-2009 08:20 AM
Deadbolt Monster TD04 with port and polish Slvrblt Car Part Reviews 50 02-20-2006 09:48 PM
Anyone maxing out their stock injectors w/the deadbolt monster td04? mcu81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-16-2003 07:19 PM
