Welcome to the North American Subaru Impreza Owners Club Saturday April 18, 2015
Old 09-11-2005, 03:49 PM   #1
left footed whooten
Member#: 44652
06 WRX
15 Forester
Default Cleaning spark plugs
Ive got a set of those iridium plugs from NDenso. Ive put probably 18-20K on them, and was wondering what the best way to clean them up was, since they are supposed to last so long? they are normally wearing, nothing looks out of place, but i figured they may need a cleaning since regular plugs get changed at shorter intervals than the iridiums.
left footed whooten is offline   Reply With Quote
Old 09-11-2005, 03:54 PM   #2
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
don't-pull-me-over Silver
I don't think you need to clean them.
Danny Boy
Danny Boy is offline   Reply With Quote
Old 09-11-2005, 07:00 PM   #3
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
You can check and re-gap them if they need it. Just becareful. I agree with DB, you shouldn't need to clean them. Unless they are coated with tar-sludge because your car burns oil. But then spark plugs would be the least of it.
cjfike is offline   Reply With Quote
Old 09-11-2005, 09:06 PM   #4
FalconRS
Member#: 92913
2005 2.5RS Wagon
Crystal Grey Metallic
Perhaps some throttlebody cleaner or something along those lines to break up carbon. But like is said above, shouldn't be necessary. If they're that dirty you have other problems. Check the gap and you're good to go.
FalconRS is offline   Reply With Quote
Old 09-12-2005, 02:34 AM   #5
Chi_San
Member#: 53558
2002 WRX Wagon
Um, easiest way to clean them? Do a seafoam treatment.
Chi_San is offline   Reply With Quote
Old 09-12-2005, 03:10 AM   #6
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
find a long hill, floor it all the way up. the plugs are now clean
00Maddog is offline   Reply With Quote
Old 09-12-2005, 03:15 AM   #7
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
When I have them out I don't use anything more than some laquer thinner and a microfiber rag to clean them.
specialev is offline   Reply With Quote
Old 09-12-2005, 04:23 AM   #8
Chi_San
Member#: 53558
2002 WRX Wagon
That's actually how I found out mine were bad. Going up a hill at WOT in 3rd for about 3 miles, then a CEL came on. Misfire in #1. Replaced plugs, no more CEL, runs better, better power, no more issues.
Old 09-12-2005, 10:40 AM   #9
sha_zapple
Member#: 41012
1998 Legacy L
Some plugs cant be regapped, and arnt supposed to be cleaned. If not, then you can use a wire brush to get the gunk (if any) off.
sha_zapple is offline   Reply With Quote
Old 09-12-2005, 10:52 AM   #10
kaisersouse
Member#: 85900
2001 Forester S
yah wire brush FTW
kaisersouse is offline   Reply With Quote
Old 09-12-2005, 01:23 PM   #11
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
isn't the iridium just a thin coating? sounds risky brushing it.
Old 09-12-2005, 01:53 PM   #12
Hayes
Member#: 11808
Never wire brush a spark plug. You end up with microscopic iron on the insulator which will cause misfires. If you feel you must clean I'd use a sand blast pencil unit with a non-conductive medium like glass shot. I can't understand why you would need to clean that type of spark plug unless it's oil fouled and then use a strong solvent.
Hayes is offline   Reply With Quote
Old 09-12-2005, 01:58 PM   #13
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
12345
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 692 12-21-2014 02:42 AM
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 03:45 PM
NEED: Plug/Clip that plugs into WRX spark plug coil BeBop86 Private 'Wanted' Classifieds 16 07-16-2008 03:05 AM
Cleaning spark plugs wcbjr Service & Maintenance 3 11-04-2002 11:08 AM
How do I clean my spark plug wires? Robmat Service & Maintenance 4 12-22-2001 12:55 PM
