#1 |
Member#: 2159
SCIC
Vehicle:2004 WRX WRB |
I know that there are some cheezy-ass replacement bulbs that are LEDs rather than incandescant lighting.
Not likely a very quantifiable savings of power consumption, but over a long drive, converting the lights from incandescant to LED lighting, along with HIDs vs. Halogens, I think that I can save a little bit of fuel by not drawing so much on the alternator. Okay. Tell me I'm nuts. As well, the frequency of replacing these lights would justify replacing them with LEDs which will last many times longer. Not buying bulbs will allow me to save on maintenance costs, or maybe eat something other than mac & cheese with current gas prices. I am curious if anyone has actually done a complete LED conversion, either with these aftermarket plug-n-play units, or other, more extreme methods, including, but not limited to: reducing the voltage in the line from it's origin to LED levels, etc.? I agree with a sentiment that Rapid Roo mentioned in one of his posts, that it can be a good idea to wake up these lazy Southern California Cell Phone Drivers when you hit the brakes. I'd rather cause panic than get hit by someone paying less than undivided attention. Additionally, I have heard of there being issues with blinkers and the like being converted to LEDs because they blink fast, or (on such equipped vehicles) trigger the 'bulb out' warning, and was wondering about such effects on our cars. I look at the likes of Mercedes & Even BMW 3-series, and the LEDs are so much sharper, and light instantaneously, and fade instantaneously, unlike the slow on and off of incandescent lights. RD ![]()
#2 |
Member#: 76896
South East
If you put LED's on, your flasher will flash twice as fast. It will see less current draw, and act like it is in "outage." (One bulb out).
Quick fix: Tridon EP-37. You have to get this from NAPA, I don't believe the others carry it. It is only a 2 pin flasher, but it will work. Plug it in one way, and if it doesn't work plug it in the only other way. The advantage is this is also a high lamp flasher, and can handle towing applications up to whatever the vehicle wiring can handle. Disadvantage is that you don't get outage (fast flash on bulb out) function, but you lose this with LED's anyway. Disclaimer: I work for the company that makes this product, and will get $.00000001 in profit sharing if you buy one. |
#3 |
Member#: 2159
SCIC
I haven't been to NAPA yet.. don't know of one around here, but I'll have to look.
If I want you to get your $.00000001 in profit sharing What about reducing the line voltage/amperage to that used by LEDs? Is something like that even possible if the whole line ONLY has LEDs on it? RD ![]() |
#4 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
The current will already be reduced. A bulb or LED will draw a specific amount of current, the LEDs draw vastly less than incandescent bulbs. The standard flasher works by sensing the current, a lower than normal draw will cause it to flash at the faster rate to indicate a blown bulb or other problem with the turn signal system. The LEDs, with their reduced current, "fake" this flasher into its outage mode.
As for voltage the LED replacements are made to work on the same 12V as the existing bulbs. Nothing to modify there. One more thing to bear in mind, the factory light housings and reflectors are designed for the output of incandescent bulbs. The LED replacements have a much narrower angle of dispersion and may not be as visible from an offset angle. Vehicles with OEM LED arrays don't have this problem since they are designed from the beginning with the characteristics of the LEDs in mind (and there are usually a LOT of LEDs in the array). |
#5 |
Member#: 2159
SCIC
light dispersion issue understood. Was actually thinking of a custom housing, or reflectors, etc. But don't want to run into the rampage of the flashers.
RD ![]() |
#6 |
Member#: 92440
Vehicle:'05 STi PSM/Gold |
Wouldn't it be the same as doing a LED swap on anything electronic. You just figure the proper resistor needed and wire it in series. Just a thought.
#7 | |
Member#: 76896
South East
#8 |
Member#: 72109
NWIC
#9 |
Member#: 2159
SCIC
Well, I have some experience with CF layup & the like, and I could interface that with the stock housings for the lights (was thinking about doing something similar for the headlights too) so the housing is not an issue. But if there isn't going to be any electrical load savings, then the whole project is somewhat worthless.
Guess I need to DL the Schematics and such from subaru Service, and take a look. I know the Low/High beams and Fogs are on relays, but I can't imagine the need for similar on brakes and clearance lights. There is no reason I couldn't just buy all the pre-made crap for LED replacement, other than the less-than optimum reflectors, and light dispersion mentioned earlier. No need to do a half-ass job well. Edit: Clean work on clearcorners.com. Some interesting ideas for sure. RD ![]() Last edited by Rubr_Duky; 09-12-2005 at 01:02 AM. |
#10 |
Member#: 69343
South East
Vehicle:2000 nothing good slow |
The trick is a 6 ohm resistor in parallel with the LED turn signal bulb. One takes care of each side (2 total.) just jump it across the leads going into each turn signal in the trunk. Some places make a nice little package that's encased in aluminum (as they get pretty warm) but getting the large, white ceramic 10 watt resistors should do as well, and mounting them away from things that might melt (they don't get that hot, but with hazards left on for 30 minutes, they might warp plastic. )
For installing LEDs in any other part of the car... dash, wherever, you need a current limiting resistor or the LED will pop. A regular red LED have about a 2 v drop. So the current from the remaining 10+ volts needs to be less than the currnet rating of the LED. Another trick is to wire 6 or 7 LEDs in series (remember they have a polarity) as 6v x 2v =12v. In general a single red led in series with a 470 ohm resistor is safe. Blue LEDs- 330 ohm. And you can play with those values a little to dim or brighten them depending on the voltage your battery/alternator is providing. But LEDs don't have much range before they turn off or burn out. The turn signal LED bulbs, and those that are sold in any pre-fit standard bulb-size package, already have that resistance built in. |
#11 |
Member#: 2159
SCIC
That still leaves me with no power savings. The resistors are still consuming (and turning into excess, undesired heat) the same power that incandescant bulbs would consume.
The point here is to be more efficient by using LEDs. RD ![]() |
#12 |
Member#: 76896
South East
Okay, here's a quick sanity check on power consumption. I'm guessing the turn/tails are around 21W. That is ~ 0.028 hp. Run all 4 all the time, and you consume just slightly more than 0.1 hp.
#13 |
Member#: 2159
SCIC
And if you drive for 8 hours straight, through the night, you have occasional turn signal, occasional brake, constant clearance, constant gauge, occasional radio, constant headlight, frequent high beam, frequent driving light, constant license plate illumination. I'm talking not a filament left on the whole car, save maybe the trunk light.
How much does that save? What about maintenance costs in replacing bulbs? Taking this to the nth degree is nuts, I agree. I simply posed the question as to how to do it most efficiently. Any time you are developing heat to burn off extra voltage (resistor) that is neither efficient, nor purposeful. Convert that to seat heaters maybe, and you've got something, but otherwise, why not limit the voltage through those wires at their source? I understand that the car is a 12v system, and yeah, 6 LEDs in series could work, in theory, but there are likely other methods, not just a big ass resistor at the power consumption end. RD ![]() |
#14 |
Member#: 76896
South East
I'm with you on not putting a big power resistor just to get flasher outage in line. I'd put in an LED flasher. The main thing I like about LED's are the quick on and off.
Check out the 3rd brake light on the new H3. It is LED, and shines through 15% privacy glass... |
#15 |
Member#: 48286
Vehicle:2005 2.5L WagonRX not black, blue or grey. |
I've been toying with the idea of this in my wagon, but it was a royal pain in the arse in my last car, and looks to be an even worse job in the wagon. There's all kinds of things you can do for an LED project. Like...To make the fast blinking stop when you install LED turns, open up the flasher and tinker around with the sense resistor on the current mirror until it's happy with the LEDs you have(you can also look at what they use for the stock resistor, figure out how much current they are expecting then modify it by a ratio).
As far as implementing LEDs by hand I found it easiest to use a 1/8w SMT resistor on every single LED. I tinkered around with some LED drivers but the end circuit ended up being a pain in the arse(I had to use a buck switching reg to drop the voltage down enough for the LED driver to survive in the car). I've been awfully tempted to do the interior in the wagon, but I see embedded filters everywhere, and those can really limit the color choices. I'm not up for another blue dash(been there, done that, bought a t-shirt). I was hoping for white, but my initial tests in the center console didn't make me very happy. I might try red next. I'll be doing the tails in the near future though. I just picked up the tails on ebay(I always save parts to give me the ability to take my car back to stock). It's pretty easy, a level dremel with the right sized bit, a crapload of resistors, and patience is all you need. Here's a guy I know of that does custom lighting(HID, LED, you name it) no affiliation with me though. http://www.illusion-lighting.com/ Here's some pics of my LED retrofit in my last car.(and here's a little how to I wrote http://www.igd4u.com/modules.php?op=...=article&sid=2 page two is most interesting as it's more universal, oh and a side note, the blue floor lighting was only only connected to the door pin, on when door open or alarm disarm only) ![]() ![]() and no it wasn't a rice mobile. this is lit ![]() I'll dig around and see if I can find pics of some of my previous LED lighting fun. I had the tails done as well as LEDs in my front markers and E46 Bi-xenon HID retrofit I like lighting ![]() |
#16 | |
Member#: 48286
#17 |
Member#: 2159
SCIC
I'll have to get to the schematic on Subaru Service, but if I'm converting everything to LEDs, I don't even see the need to feed 12v to the tail lights, or like 2phless said use 6 leds in series to work it out, which does seem doable. It won't have the amperage load that the bulbs would, but would still require 12v? Seems doable, especially if I'm doing a scratch 'retrofit' job.
HIDs is another step I am seriously thinking about doing, not necessarily for the power savings, though that doesn't seem like a bad bonus, but for the increased lighting, and control over it. Again, some ral good ideas in this respect from clearcorners.com I route PC boards for a living, so something like this, given the right schematic seems like it should be pretty easy. The fab work should also prove pretty interesting, with all the available options, like reflectors, projectors, and light-pipes, I think I can get a pretty clean, cool look. I'll definately post, and if it's easy enough, it could be duplicated. 2 projects ahead of this though, just thinking out loud. Good work on the LED conversion, Illusion.. never thought of SMT resistors, though I might try that in my gauge cluster when I get around to it instead of 'bulb condoms' RD ![]() Last edited by Rubr_Duky; 09-13-2005 at 08:58 AM. |
#18 |
Member#: 48286
Two things I found through my adventures in LEDs. SMT well SMD(surface mount device, instead of surface mount transistor since they aren't transistors lol) resistors since it makes putting them in small places much easier. For the most part I used original bulb sockets throughout the dash in the accord. Just slipped an LED in base, then put the resistor on the back. The other finding was cutting off the dome on the LEDs to give them a soft even lighting instead of a focused beam. Most real wide angle LEDs have a very little output so they would be dim.
For those too lazy to visit my site. regular LED unaltered ![]() after making the dome flat with my dremel ![]() the back of one of my altered bulb sockets ![]() Rubr_Duky. HID is a wonderful thing, especially when you go to OEM projectors. I have modified JDM STi HID right now, and I'm sad I spent the money for the housings because the output is crap. I spent 1/2 the price on putting the HID projectors in my accord and the output was fantastic. I'm getting on in age and my night vision isn't getting any better. The projectors in my accord ROCKED. ![]() don't mind the drivers side, I hadn't tweaked it yet and it was a bit off kilter ![]() plus they looked pretty mean during the day(I got some cheap ass ebay projectors, yanked out the junk low beam optics then added my HID projectors) ![]() |
#19 |
Member#: 2159
SCIC
Sweet.
I am currently looking at the Bosch projectors from hidplanet, though I am going to wait and see how feasible this LED thing is before I start buying. I HATE doing things twice, and what I have in mind will likely take me to a custom housing if I can get all the bits together, and can find a way of molding the parts just right, and some other loose ends that need squaring. That stated, it should be an interesting project, and if I can execute what I've got in my head, it should look pretty decent as well, and will be just a little bit different than stock, though much cleaner a unit than some that I have seen. Not to take away from the hard work that some people have put into HID retrofits, but I have been less than pleased with the appearance of the unit, but I agree, the lighting difference is well worth the energy and expsnse. I think if done correctly, the LEDs give a much cleaner, tighter appearance to the car, which is why I have thus far shied away from the available lighting options, because IMHO they just look kinda sloppy. Call me a neat freak, and a hypocrite because I don't often wash my car, I like little projects like this, because it's unique. Plus, I'm a freak. RD ![]() |
#20 |
Member#: 69991
South East
Vehicle:Leh Keen Approved |
interesting on grinding the top off of the LED. I use wideband that are upposed to give off a less focused light. hmmmmm
#21 | |
Member#: 48286
My favorite LED is still the Luxeon Star V, I have a few of them, but haven't found anything to do with them because they are power hogs(700ma@7V), and just silly bright. They are spec'd at 30lumens(1,250,000mCd)...but the odd part of that spec is the 150° viewing angle, which means if they were a focused beam they would just be insane. I have a Collimator lens coming which supposedly turns a luxeon star into a 10° animal. I'm getting it for free so I'm being patient with my supplier ![]() |
#22 |
Member#: 2159
SCIC
What's that? LED Projector Fogs?
![]() RD ![]() |
#23 |
Member#: 48286
probably could be if I could get the beam adjusted right.
Oh and a side note for fellow nerds. The best LED site around http://ledmuseum.home.att.net/ledleft.htm and an interesting collection of things I just ran arcoss. http://www.emanator.demon.co.uk/bigclive/makendo.htm Hmmm his RGD LED driver board can support 1000 LEDs a channel....RGB dash lighting? ![]() |
#24 |
Member#: 27752
VIC
Vehicle:2004 WRX+Ver.8 EJ207 Silver |
Y'know the whole quick-flash LED issue isn't one. The Police, atleast in my area (Canada!), do not care. I actually asked an ex-police friend what his opinion was and he brought over an active officer to check it out. I got 4 thumbs up from them saying the color was perfect and the intention is clearly an indication of turning. They both liked the high intensity of the 19 LEDs per bulb and were impressed with the angles of radiance the LEDs were providing.
![]() (That's a bad pic but I can't find the sweet closeup we got of the LED in action.. It's very intense!) |
#25 |
Member#: 45089
International
Vehicle:2008 DGM STI -R Spec 2010 BMW X5 ///M |
| Thread Tools | |
| Display Modes | |
| LED conversion question | breadstick | Electrical & Lighting | 1 | 11-02-2006 10:54 PM |
| Surefire E2E LED Conversion Question | Call_me_Tom | Off-Topic | 13 | 01-01-2006 03:59 PM |
| gas light on after led conversion | rabbitnutz | Electrical & Lighting | 6 | 04-21-2004 08:48 PM |
| Just finished my blue LED conversion! | Speedwagon | Legacy Forum | 15 | 05-09-2003 09:06 PM |
| Just finished my blue LED conversion! | Speedwagon | Mid Atlantic Impreza Club -- MAIC | 12 | 05-09-2003 06:58 PM |
