Old 09-11-2005, 09:34 PM   #1
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
Default okay now i'm confused
I was having idle problems with my car so i made the assumption that it was my fuel filter since i hadn't changed it in close to 25,000 miles anyway so i went ahead and did it anyway-that did get rid of some of the problems but i'm still having some of them
a rough idle, every now and then when sitting at idle shortly after i start my car at an intersection it will jump up to 2k+ and slowly drop
sometimes after starting it will idle at approx 1,000 and won't drop down to normal til i've been driving for several minutes sometimes not at all.
a rough start, sometimes it will struggle to start acting like it's not getting gas to the engine-my car is an auto and it acts like a stick without fuel injection
when i changed the fuel filter i also added an auxilary inline fuel filter (one of those cool clear ones from GI joes) and i ran some injector cleaner with my next fill of gas
I need help to say the least, it's really frustrating...
~Mike
pilfflip is offline   Reply With Quote
Old 09-11-2005, 09:53 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
bad gas, bad plugs, bad wires...ecu reset in order.
My idle is rather odd as well, but from what I've read its kinda subaru trademark
Good luck,
fibuz
fibuz is offline   Reply With Quote
Old 09-11-2005, 09:58 PM   #3
LegacySTI
Member#: 86621
95 If it brakes
Mod it
I had the exact same problem on my 95. Idle control sensor.
LegacySTI is offline   Reply With Quote
Old 09-12-2005, 12:25 AM   #4
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
if all of the above fails, try some seafoam and clean out your intake, injectors, etc...
Wiscon_Mark is offline   Reply With Quote
Old 09-12-2005, 12:54 AM   #5
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
I've had this on vehicles before and it was usually egr related. Check to see if all your emmisions stuff is working ok. Idle can be affected by vacuum, and vacuum can be affected by emmisions...
janikphoto is offline   Reply With Quote
Old 09-12-2005, 01:42 AM   #6
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
If coil, wires, plugs, fuel check good, then Idle Air Solenoid or throttle body in that order. Some walk throughs that I've posted previously...
IAS walk through POST # 10.
TB walk through POST # 5.
HTH
Dale
Subietonic is offline   Reply With Quote
Old 09-12-2005, 12:41 PM   #7
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
Alright, my plugs and wires are brand new with less than 3,000 miles. I'm going to jump to the conclusion that it's either the Idle control sensor, good thing i have one of those sitting around-i just hope it's still good.
I know that strange idling is kind of a subaru trademark but this is out of the ordinary, and has this strange way of seeming "not right", I'll throw on that sensor and see if it works.
~Mike
Okay NOW I'm Friggin Pissed!!! OriginalSin Off-Topic 22 02-27-2008 04:55 PM
Okay, now I'm scared rogue Brakes, Steering & Suspension 12 09-30-2004 06:15 PM
Now I'm confused, [email protected] says 225 should be OK on wagon Orson Tire & Wheel 6 10-23-2003 08:08 AM
Now I'm confused!!! Rimmie Technical Forum Archive 6 06-13-2000 07:23 AM
