Old 09-12-2005, 03:59 AM   #1
93subi
Member#: 81255
98 05 LGT, silver
98 Trans AM, Red
Question ECU's
I am looking to get more power out of my frakenstien motor. what I would like to do is replace my current 1993 1.8L ECU for a 1991 legacy 2.2L ECU. has anyone done this before or can it even be done? I know the plugs from the 1.8 harness are probaly different from the 2.2 harness but is there anyway I can get around this, like wire the 2.2 plugs onto the 1.8 harness,
Mike
93subi is offline   Reply With Quote
Old 09-12-2005, 12:32 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Why do you think the 2.2 ECU is going to give you any more power?
Personally I wouldn't spend the time swapping connectors over for questionable performance gains...or losses.
Legacy777 is offline   Reply With Quote
Old 09-12-2005, 12:40 PM   #3
83Rabbit
Member#: 5050
Youll need the 2.2 intake manifold/TB and all connectors/sensors and the wiring harness and a few other odds and ends IIRC.
83Rabbit is offline   Reply With Quote
Old 09-12-2005, 01:48 PM   #4
93subi
Member#: 81255
98 05 LGT, silver
98 Trans AM, Red
guess its not worth it then. thanks for the help
Old 09-12-2005, 02:41 PM   #5
83Rabbit
Member#: 5050
itd be more worth it and more beneficial if your doing future mods to get an S-AFC or Emanage or something along those lines to tune your car a bit than swapping over all the parts for a minimal gain if any.
Old 09-12-2005, 08:32 PM   #6
93subi
Member#: 81255
98 05 LGT, silver
98 Trans AM, Red
what would you recomend? emanage or the S-AFC
Old 09-12-2005, 09:07 PM   #7
The Stig
Member#: 91322
2005 WRX
The EM can control more things, fuel, ignition, vtec control if so equipped. You can also hook up a pc to the unit and have even more control over the fuel curve. The S-AFC is a self contained unit and has a limit on the fuel manipulation, that i believe is lower than the EM. Personally if you can get the wiring done correctly I would go with the EM. The EM looks like a mini amp too
The Stig is offline   Reply With Quote
Old 09-12-2005, 10:01 PM   #8
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
yah dude. in a couple weeks im wiring the safc to my 95 1.8L
t3hWIT is offline   Reply With Quote
Old 09-12-2005, 11:52 PM   #9
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
post you results im sure my bro and tons of other guys need it
99subi is offline   Reply With Quote
Old 09-13-2005, 12:12 AM   #10
t3hWIT
Member#: 58779
95 STi RA (rhd)
i plan to, if we can change settings without breaking stuff. no wideband. i have noteiced the lack of info on this for the 1.8L thoh...
Old 09-13-2005, 08:30 AM   #11
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
well, as a performance upgrade, I think the EJ22 manifold has bigger ports and allows for a better overall flow.
JonofScio is offline   Reply With Quote
Old 09-13-2005, 09:09 AM   #12
Legacy777
Member#: 4800
The manifold doesn't have bigger ports, the heads have larger valves. So unless you swap the heads, you're not going to gain anything.
Old 09-13-2005, 09:51 AM   #13
83Rabbit
Member#: 5050
Id reccomend the Emanage if you have the extra dough to spend. S-AFC I would do if I got the hookup on it, like if my friend was selling it for cheap and it came as a good deal. I would install it, see how it suited my needs and go from there. But if your starting cold, you might as well go ahead and drop the extra money on something that will be even more useful later.
Old 09-13-2005, 10:51 PM   #14
93subi
Member#: 81255
98 05 LGT, silver
98 Trans AM, Red
how much is an EM system gona set me back?
Old 09-19-2005, 07:38 AM   #15
t3hWIT
Member#: 58779
95 STi RA (rhd)
i looked myself, as ai42's 1.8T conversion got me started here.
the emanage is found here along with other optional parts(prices):
http://www.greddy.com/prod_e_manage.htm
I personally would prefer the emanage over the safc, but the emanage is a bit more than i can afford right now. that, and the safc was priced right.
Old 09-19-2005, 11:59 AM   #16
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Actually,
The Ej22e heads AND manifold have 1/8" larger ports than the Ej18 parts do. I have measured them myself...
Old 09-19-2005, 01:08 PM   #17
Legacy777
Member#: 4800
Originally Posted by Matt Monson
Actually,
I see. I think (took it) though that he just wanted to swap the manifold...which wouldn't really work.
Old 09-19-2005, 09:54 PM   #18
93subi
Member#: 81255
98 05 LGT, silver
98 Trans AM, Red
i have actually herd that the 1.8 intake monifold was slightly tuned as the subaru tech put it. he sayed they are equal lenght, does any one no if this is true?
ECU's - Prodrive ECU travmn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 12-13-2001 05:09 PM
WHat are the Subaru Programable ECU's SHADOWES Normally Aspirated Powertrain 2 06-27-2001 05:56 PM
Jprova ECU's from Japan Mako Normally Aspirated Powertrain 0 04-13-2001 05:36 PM
Battle of the ECU's. Haltec vs TEC-2 Digital_Boy Normally Aspirated Powertrain 16 10-24-2000 08:50 PM
Programmable ECU's... what kinda options out there? 8Complex Technical Forum Archive 25 07-07-2000 12:49 AM
