Old 09-12-2005, 09:53 AM   #1
rayyoung05
Member#: 93771
Default ej18 bore
will boreing out my 1.8 ltr impreza be a good idea?
rayyoung05 is offline   Reply With Quote
Old 09-12-2005, 01:58 PM   #2
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
sure! as i understand it, all EJ engine blocks start out as 1.8's and are then bored out to the target displacement. IF that is true, then u could potentially end up with an EJ25 guaranteed to be compatible with ur vehicle and for a fraction of the cost...
bongchild is offline   Reply With Quote
Old 09-12-2005, 02:24 PM   #3
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
would that explain why the ej18 could hold so much boost considering the compression? btw, why bother upping the displacement? why not just get a bigger block/engine?
t3hWIT is offline   Reply With Quote
Old 09-12-2005, 02:44 PM   #4
rayyoung05
Member#: 93771
Default ?
i figure it would be a wiring nightmare scince its 2 differnt enginse and its front wheel drive
Old 09-12-2005, 03:29 PM   #5
83Rabbit
Member#: 5050
Its really not, the 2.2 can be done with minimal work and the 2.5 which I am underway in doing can be done with a minimum of just swapping connectors and sensors and spicling 4 wires for the coil.
83Rabbit is offline   Reply With Quote
Old 09-12-2005, 05:17 PM   #6
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
Probably. The 9mm cylinder walls and forged internals have a LOT to do with it. BTW, do any of the gurus know if the EJ18 forged internals myth has been busted or cofirmed??
Last edited by bongchild; 09-12-2005 at 05:21 PM. Reason: I watch too much tv.....
Old 09-13-2005, 08:39 AM   #7
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
The EJ18/20/22/25 are all the same dimensions block, same size deck, just at different bores, combinations of fully closed, semi, and open deck, and between the E and 1 versions, just more or less cylinder wall. As I do believe, the last time my friend measured, his EJ18 had 13mm of wall thickness, and the last time I measured, my EJ22 had 9mm. Which does make for good math, that of the piston bore difference.
in either case, if you bored out the walls and put in cylinder sleeves, you wouldn't be able to tell the difference of the block between an EJ22 that had cylinder sleeves.
If you wanted to, the choices are limitless... You could sleeve it for 2.5L pistons, and drop a phase I crank/rod/piston setup in there, get a 2.2L manifold and heads, ect. and run with an 11.5:1 monster. who knows, it's up to you. Or you could just go get a shortblock EJ22 and drop it in.
JonofScio is offline   Reply With Quote
Bored... RideAllnight Off-Topic 24 06-02-2010 01:52 PM
Bore Size of EJ18 MeanEditor Normally Aspirated with bolt-on Forced Induction Powertrain 3 03-25-2007 04:10 PM
RE:USDM EJ18 swap to EJ22 JDM or JDM EJ18 cbrkp Subaru Conversions 2 12-06-2006 03:07 PM
I'm bored. Anyone else bored? Siper2 New England Impreza Club Forum -- NESIC 19 10-04-2001 08:06 AM
Bored Bored Bored WagonMonster Southern California Impreza Club Forum -- SCIC 24 05-24-2001 12:09 AM
