Old 09-12-2005, 11:03 AM   #1
DDB
Member#: 66339
Default Anybody replaced power steering pump on Legacy L?
I just obtained a power steering pump from a junkyard for my '97 Legacy L (only $50, not bad!).
I have the Haynes manual at home, but haven't looked at the info yet for this replacement. Any 'gotcha' items I should be aware of?
Thanks,
DDB
DDB is offline   Reply With Quote
Old 09-12-2005, 07:25 PM   #2
LegacyJones
Member#: 48791
02 bugeye
wagon
It should be pretty strait forward. Just watch the fluid. $50 is a good price. I wish more people would use junk yards. Or as i like to call them hiden treasures.
Jason
LegacyJones is offline   Reply With Quote
Old 09-12-2005, 11:38 PM   #3
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Did you buy it with the pulley attached or separated? If you have to replace the pulley, make sure you don't take off the PS belt until you undo the pulley nut. Unless you have a pulley spanner that can lock/hold the pulley in place, and depending how tight the wrench monkeys installed it and how corroded it is, it may be a beotch to get off. Leaving the belt on, allows you to hold tension on the pulley with the belt while you loosen the nut.
If your "hidden treasure" already has the pulley, just check it to make sure it doesn't have any dings, nicks or out-of-round surface area before you re-install it.
Good luck.
Dale
Subietonic is offline   Reply With Quote
Old 09-13-2005, 11:45 AM   #4
DDB
Member#: 66339
Thanks for the feedback, guys. The PS pump came with the pulley attached. I don't think I'll be able to tackle this project until the middle of next week. I'll post an update then.
- DDB
Old 09-28-2005, 09:12 AM   #5
DDB
Member#: 66339
Default UPDATE: Performed replacement last night
I finally got around to swapping out my old power steering pump for the one obtained at a junkyard recently. The process went fairly smoothly. I made a bit of a mess on my driveway with the old PS fluid, but not too bad.
Filled 'new' pump with Mobil1 synthetic ATF, bled the system per the instructions in the Haynes manual, and that was it. The old problem of rubbing/creaking noises when turning the wheel at slow speeds has disappeared.
Job took me a little over an hour, which probably means that anybody else could do it in 30 minutes (I'm the world's worst amateur mechanic).
- DDB
How To: Change a power steering pump on WRX/STi Gamble_WRX Service & Maintenance 23 04-06-2013 08:22 AM
JDM power steering pump fit legacy ? IllNastyImpreza Subaru Conversions 0 02-18-2008 01:54 PM
Replacing Power Steering Pump... NothnButTheFacts Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-18-2007 07:25 PM
04 power steering pump on an 02? wrx_snobordr Brakes, Steering & Suspension 3 05-10-2005 12:47 PM
How many bolts hold on the power steering pump on an STi? Physics Junkie Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 01-09-2005 12:07 PM
