Old 09-12-2005, 12:37 PM   #1
FromEvoToRS37
Member#: 91396
Default plans for avo
I am plannin on turboin my 2.5 rs with the AVO turboworld turbo kit, Ive heard turboin the 2.5rs isn't a great idea cause the engine isn't strong but I read a review sayin it will put the car at around 271hp at the crank and i forget how much at the wheels but it'll beat a wrx and is almost in the sti territory if you add header high flow cat and exhaust maybe some other things too, anyone have this kit or heard of someone with this kit and recommend it or say anythin about its reliability and if turboin the car with this kit will handle thanks for any help
FromEvoToRS37 is offline   Reply With Quote
Old 09-14-2005, 05:47 PM   #2
FromEvoToRS37
Member#: 91396
woulda thought someone would know somethin bout it
Old 09-14-2005, 06:18 PM   #3
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
Legacy
with every turbo conversion there is a certain amount of risk involved, ive never personally seen an avo kit running on an RS, but I hear good things. When i turboed my ej22 i just did a wrx set up, with EJ22T injectors and rails, and controlled it will a greddy emanage. I am also running between 5-6 psi daily on 93 octane with no audible knocks. the EJ22 has lower compression (9.5:1) as opposed to the EJ25 that you have with about 10.0:1 maybe higher (i cant remember) and the EJ22T's had 8.0:1 pistons.
AS long as you have a good tune and good engine managment and you dont stray too far past 5psi the kit is fine. Its all about how deep your pockets are and what kinda hole you want to put in em.
Just dont buy a kit from turbokits.com those = worse than a leaf blower -> intake
Kawikid20o2 is offline   Reply With Quote
Old 09-14-2005, 06:53 PM   #4
Tats
Member#: 5692
WTF? YES! I am
better than you!
I have/had it...it's PLENTY fast.
You will definately need a stronger clutch. Do it before the turbo goes in a save a lot of time and aggravation(sp?)
If you want to experience it at it's best you should get a 2.5" cat back or bigger.
Forget the headers...you'll spool later. And the kit comes with a high flow cat in the DP already.
Any Q's PM me.
Tats is offline   Reply With Quote
Old 09-14-2005, 07:49 PM   #5
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
RalliTEK is trying to come up with a new kit based on Momentum's EJ5-40T and PerfectPower (which is still considered a piggy but a powerful one nonetheless) - uses the same flange as USDM WRX and STi
kgb is offline   Reply With Quote
Old 09-15-2005, 03:18 PM   #6
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
When? How much? Ima e-mail them some questions right now, ;-)
Sko is offline   Reply With Quote
Old 09-15-2005, 04:41 PM   #7
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
They said they want to bring it in below $3500USD - I suspect not but it shouldn't be too far out
Old 09-15-2005, 07:08 PM   #8
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
I have talked to rallitek about the new setup and it will be 100% better then most kits in that it has good engine management right out of the box. I down consider the PP to be the best piggyback out there but they have a good strategy for implementing it for the RSt which will be a nice reliable solution.
I would definitely recomend it.
Todd
Hitokiri is offline   Reply With Quote
Old 09-16-2005, 12:43 PM   #9
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
One of the thing is that PP seems to support staged injection and RalliTEK is keen on putting an extra injector on the TB when you go for the fueling upgrade. I'm still waiting to see where they are going to mount the TMIC because the outlets just don't make sense at the traditional location - it almost looks like they figure out how to mount it behind the grill which where I would have mounted an intercooler
This is what you've been waiting for! AVO Turbo Kits! Rallitek.com Vendor 'Group Buy' Classifieds 37 03-10-2014 08:48 AM
FS: (MA) AVO VF37 VF36 Bellmouth for AVO or Custom Twinscroll Downpipe atc5 Engine/Power/Exhaust 43 05-12-2010 03:26 PM
Plans for the new car. Need part #'s for STi headlamps and... 3DF Private 'Wanted' Classifieds 5 02-28-2005 04:40 PM
First Bush Ignored Clarke Plan for AQ, Then Rejected Pentagon Plans to Get Zarqawi RRinDC Political Playground 18 09-29-2004 04:13 PM
Replacing VF30 for AVO 450hp WRX8U Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-08-2003 10:26 AM
