Old 09-12-2005, 01:40 PM   #1
LegacySTI
Member#: 86621
95 If it brakes
Mod it
Default Does anybody with a BD run without a cat?
I was wondering if any BD guys ran without the cat. and if so, do you have any problems with it?
LegacySTI is offline   Reply With Quote
Old 09-12-2005, 02:07 PM   #2
Perdue
Member#: 57431
98 Legacy GT
04 Dakota QC 4x4
I ran mine catless for a while. I used the O2 Sensor Spacer from Rallitek and didn't have any problems, CELs, or anything else. It was extremely loud though and I will not do it again.
Perdue is offline   Reply With Quote
Old 09-12-2005, 02:24 PM   #3
KD7000
Member#: 16653
2012 Mazda 3
2004 Honda Pilot
Why do you want to run catless?
A good high-flow converter will make about as much power as a "race pipe" but still keep the environment happy.
It'll also keep your car legal- do they test emmissions in your state?
KD7000 is offline   Reply With Quote
Old 09-12-2005, 02:31 PM   #4
Kraziken
Member#: 38629
1999 Legacy GT (STI)
They do tests in WA, but they just plug in a reader to the OBD port. You can make mods so the computer reads the cat is functioning properly.
From the folks I talked to, even with out the cat, a new subie, might be able to pass a sniff test, but I'm not positive.
I won't run catless because of my conscience. I'm getting a hi-flow turboxs cat for my car.
Kraziken is offline   Reply With Quote
Old 09-12-2005, 03:14 PM   #5
Gil
Member#: 20872
t3h rubber-neckers
must die!
I've been running a gutted cat since i got it in Oct 03. CEL came on a few months later, sometime in the spring.
I replaced the rear O2 sensor cos it looked pretty beatup on visual inspection, and the CEl has been much better behaved. Now, it only comes on when I go from crusing at alittle over 3,000rpm to a little under 3,000. I'm thinking the next thing i might need to do is to replace the front O2 sensor.
Been looking for a hi-flow cat, but haven't been able to find a decent one that i'm able to comfortably afford.
Gil is offline   Reply With Quote
Old 09-12-2005, 04:36 PM   #6
LegacySTI
Member#: 86621
95 If it brakes
Mod it
The reason I ask is because I have a stromung track pipe and my car is running really rough, the dealership says its because I have no cats and the O2 sensor are overloading the system
Old 09-12-2005, 07:08 PM   #7
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
sounds like you need something to "fool" your o2 sensor so you stop running rough. You could pick up something like this for cheap.
Wiscon_Mark is offline   Reply With Quote
Old 09-12-2005, 10:18 PM   #8
Gil
Member#: 20872
t3h rubber-neckers
must die!
and just what might this "thing" be??
Old 09-12-2005, 10:32 PM   #9
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
Originally Posted by Perdue
. I used the O2 Sensor Spacer from Rallitek...
I believe you can also get it from boxer4racing...I got one, because my hi-flow cat just arrived today!
Old 09-13-2005, 05:53 AM   #10
Perdue
Member#: 57431
98 Legacy GT
04 Dakota QC 4x4
IIRC, Boxer 4 uses electronic bosses to control the o2 sensor, but from what I've heard, these will sometimes still give a CEL with a fully catless system. I'd say get the spacer from Rallitek (Boxer4 might sell'em...too lazy to look). It worked well for me, but what works well for one ECU might piss off the other ECU.
Old 09-13-2005, 07:00 AM   #11
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
+1 for the spacer... It's what I use and I've never tripped a CAT inefficiency code..
xcntrk75 is offline   Reply With Quote
Old 09-13-2005, 08:14 AM   #12
Gil
Member#: 20872
t3h rubber-neckers
must die!
I'll give it a shot.
Old 09-13-2005, 08:17 AM   #13
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
I dunno if they have it listed on their webpage, but they threw one in for me when i purchased my stromung Hi flow cat from them
Old 09-13-2005, 08:20 AM   #14
Oquipah
Member#: 9689
1998 Legacy GT
According to boxer4, they have an electronic boss, however will have another option (non-electronic) for the BD's soon. As of last week it was still not on theier website. Give them a call.
Peace,
Oquipah
Oquipah is offline   Reply With Quote
Old 09-13-2005, 12:07 PM   #15
Gil
Member#: 20872
t3h rubber-neckers
must die!
what's an electric boss?? in fact, what's a boss?
Old 09-13-2005, 12:14 PM   #16
Russell Rogers
Member#: 27261
1999 www.prjct1.com
I'm Ron Burgundy?
go back to ahving cats. NA Subaru's make more power with cats unless the ecu is heavily tuned.
Russell Rogers is offline   Reply With Quote
Old 09-13-2005, 01:03 PM   #17
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
More power, or more torque?
I've never seen a dyno plot with a higher HP reading of cat vs. no cat.
Huffer is offline   Reply With Quote
Old 09-13-2005, 01:59 PM   #18
Russell Rogers
Member#: 27261
1999 www.prjct1.com
I'm Ron Burgundy?
Both. NA subarus do not scavenge exhaust well without cats. Let alone the fact that running no cats in washington state is risky.
Old 09-13-2005, 03:39 PM   #19
Huffer
Member#: 36735
99 GF8 Impreza 2.0
Surely scavenging is a byproduct of the exhaust design, not dependent on the inclusion of a catalytic convertor?
(ignoring EPA requirements for the sake of argument)
Old 09-13-2005, 04:36 PM   #20
Perdue
Member#: 57431
98 Legacy GT
04 Dakota QC 4x4
my car seemed to have more power in the upper rpms actually, this being with EJ22, Borla Headers, Catless with just a canister style muffler. This ended up being way too loud, as I stated above, and really raspy, causing the exhaust to frankly sound like crap. I dunno how much it would differ with the Borla Turbo muffler I'm running now, but I'd rather not find out.
Old 09-13-2005, 04:38 PM   #21
Russell Rogers
Member#: 27261
1999 www.prjct1.com
I'm Ron Burgundy?
exhaust backpressure has a huge role in scavenging.
Old 09-13-2005, 06:44 PM   #22
Oquipah
Member#: 9689
1998 Legacy GT
Here's a description of the O2 sensor boss from boxer4:
http://www.teaguesauto.com/exhaust.htm
Old 09-13-2005, 07:08 PM   #23
Gil
Member#: 20872
t3h rubber-neckers
must die!
you mean the resistor mod?
Old 09-13-2005, 10:24 PM   #24
Huffer
Member#: 36735
99 GF8 Impreza 2.0
That's correct, but that doesn't mean you have to run catalytic convertors to achieve the same effect.
Pipe diameter, addition/subtraction of bends, resonators etc all contribute to the famed "backpressure" phenomenon.
Do you have any proof that a catless system is less powerful vs. a catted system (ceteris paribus - all things being equal)?
Old 09-14-2005, 11:28 AM   #25
gumball
Member#: 1209
I’m not sure why you would want to do this to a daily driver. The cat cuts down carbon monoxide, NOX and, most importantly toxic hydrocarbons. There is some nasty, volatile stuff that comes out of engines- most notably benzene, olefins, formaldehyde, all of which have neurotoxic, carcinogenic, reproductive and developmental toxicity effects. The cat reduces or eliminates a substantial amount of these hydrocarbons, without it you, your kids or whoever are breathing in a daily dose every time you back out of the driveway or pull out of your garage. Not worth it IMHO.
gumball is offline   Reply With Quote
Does anybody have a V3 running! chris sanborn Pre-2002 Factory Turbo Powertrain 29 06-05-2007 11:33 AM
Legacy GT BD running GR2's with stock springs Rasheed Legacy Forum 29 09-23-2005 11:29 PM
Chicago: Does anybody have a 2.5rs with a high flow cat? kamil212 Mid West Subaru Owners Club Forum -- MWSOC 6 09-22-2005 08:04 PM
Anyone running without 3rd cat in E-town jjjheimer Canada Region Forum 15 04-19-2003 02:26 PM
Does anybody else have snowmobiles running around thier neighborhood? tcs007 Mid West Subaru Owners Club Forum -- MWSOC 8 01-31-2002 06:46 PM
Message Board Statistics All times are GMT -4. The time now is 10:21 AM.
