Old 09-12-2005, 05:24 PM   #1
pl1ght
Member#: 60094
Default Newb brake/rotor question
Hi, i plan on changing my brake pads with Hawk pads and the rotors with direct replacment Slotted rotors from www.daddysscp.com. 2002 WRX
I have found the howtos for the brake pads etc. i am not changing the SSlines or caliper or anything. My question is, is it as simple as unbolting rotor, bolting new one on, then replacing the brake pads? Do i need to bleed the brakes? or can i just eye the brake fluid level? since i am not changing any lines or rotors im guessing i dont need to bleed anything. Thanks for any insight
pl1ght is offline   Reply With Quote
Old 09-12-2005, 05:41 PM   #2
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Fluid Change/Bleeding
You don't have to bleed the brakes but you might want to since its pretty easy to do once you have the wheels off. You might check to see if you are due for a fluid change. Might be a good time to do this. I would consider using a high temp synthetic fluid. I really like my SS lines. Really gives you a lot of pedal feel.
cdigerlando is offline   Reply With Quote
Old 09-12-2005, 06:14 PM   #3
ralliharri
Member#: 85035
2011 WRX 5-door
KTM 690 Duke
Yup, just unbolt the calipers and screw a pair of M6 ( i think it was) bolts into the little holes on the rotor to bring thme out. Remember they're directional (the rotors ie). Would be a good idea to bleed the fluid if not done before.
ralliharri is offline   Reply With Quote
Basic brake/rotor question.. redsunsfd Newbies & FAQs 7 02-09-2008 10:50 PM
brake rotor question scooby_wooby Brakes, Steering & Suspension 1 01-24-2006 11:42 PM
Newb Brakes question. V-lad Newbies & FAQs 6 11-30-2005 05:59 AM
A newb brake question psaeko Brakes, Steering & Suspension 1 01-14-2004 10:30 PM
Questions about brakes - rotors, plating and bias BoomerRS Technical Forum Archive 13 08-16-2000 05:39 PM
