Old 09-12-2005, 08:11 PM   #1
04STiguy
Member#: 36234
2005 WRX STi
CGM
Default FMIC's, summertime roadracing and engine coolant temps....
Anyone here who has an FMIC and roadraces in hot ambient temps? I am worried that by adding an FMIC to the car it will cause issues with my engine cooling while open tracking at Willowsprings and Buttonwillow. Ambient temps frequently hit 95-100F+ in the summer.
Any feedback data (specifically those that have done this) would be appreciated!!
04STiguy is offline   Reply With Quote
Old 09-12-2005, 10:07 PM   #2
BLACK02WAGON
Member#: 32574
2012 Nissan GTR BE
Vibrant Red
Impreza WRX STi
I have the TurboXS FMIC and have spent some time at summer auto-x and one trip to VIR in July and have had no problem. That being said, I did upgrade my entire cooling system(full Al radiator, hoses, and tstat) and added a oil cooler. If you are gonna push it, why not make sure its gonna be safe.
Good Luck
BLACK02WAGON is offline   Reply With Quote
Old 09-12-2005, 10:18 PM   #3
scoobie1
Member#: 41559
2007 Brocoma
Although I haven't taken it to a track since I've installed it, my last auto-x was the reason I installed a FMIC. On the day of the event the heat index was ~105 and the temp was around 95 or so. By the end of my 5th lap, the stock TMIC couldn't keep up and my UTEC started pulling a little timing. I was on the I/C spray button constantly and also was popping my hood between laps to let some of the heat out. Track days aside, I think the heat here alone is enough to warrant a FMIC just for hard daily driving.
scoobie1 is offline   Reply With Quote
Old 09-13-2005, 12:26 PM   #4
doubleurx
Member#: 64024
03 996 TT, 964 C4
salt and pepper
You need to do something. I am in the same boat. I was at a track day with 100+ temps and at WOT on the straights, i had increased coolant temps. It went back down immediately. I'm going to start cheap with just a radiator shroud, better thermostat and some water wetter. If it is still a problem then it's going to be the whole new radiator. Around town I never see elevated temps, only at the track.
doubleurx is offline   Reply With Quote
P0118 Engine Coolant Temp Sensor High Input j.r Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 05-25-2009 06:17 PM
Engine Coolant Temp Sensor ? qwiktripn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-13-2004 06:49 PM
Engine Coolant Temp Sensor scoobyimprza Engine Management & Tuning 3 11-14-2002 02:19 PM
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 02:42 AM
CEL = engine coolant temp. sensor jrlegac8195 Service & Maintenance 1 10-30-2002 02:14 PM
