Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 09-12-2005, 10:14 PM   #1
RSblood
Member#: 87778
2015 Ford Focus ST
Race Red
Default NOS?? Good or Bad on '00 RS??
My friend amzingly is able to hook me up with a free used NOS kit from a shop he knows and just got alot of work done at, the nos kit was originally used by a dumbass who blew his engine ( not sure what car ) and he is now giving it away. It is a 100 shot nos but to be on the safe side i would get a 50 shot nozzle because i have heard bad thing, Im just wondering if this is a good idea to install on my 2000 2.5 RS with the only engine upgrade being an AEM short ram intake, also do I need other modifications to have it work? Any recomendations on what i should do, after all, it is free...
RSblood is offline   Reply With Quote
Old 09-12-2005, 10:15 PM   #2
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
i heard that every time you use nitrous you take 1000 miles off your engines lifespan. that is, assuming you dont blow your engine when you use it
svek is offline   Reply With Quote
Old 09-12-2005, 10:17 PM   #3
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
is there less than a 50 shot available? you got engine management?
t3hWIT is offline   Reply With Quote
Old 09-13-2005, 01:27 AM   #4
D fresh
Member#: 95459
the activity level
of AutoX is > than F1
That is utter BS.
It'd be helpfull to know what it came off of.
I wouldn't worry about a 50 shot ruining your engine. As long as it is not used excessively.
D fresh is offline   Reply With Quote
Old 09-13-2005, 01:36 AM   #5
Impr3zy0u
Member#: 93404
Impr3zy0u is offline   Reply With Quote
Old 09-13-2005, 01:59 AM   #6
svek
Member#: 82259
1999 impreza 2.2L
i heard it from my auto teacher in hs
Old 09-13-2005, 02:20 AM   #7
Guru Imakuni
Member#: 58773
RSblood, the RS is not the ideal setup but then again people stick nitrous on anything. From what I've read nitrous can be safe on just about anything too, if properly installed and safely used. I believe it's illegal to use on the street too... It's really a ricers wet dream in that it's only made to go fast for a short time (light to light), is relatively inexpensive, and can bling out anything even if with a microscopic shot of juice. Now since it's free...just be careful!
I don't think I've ever seen you say something remotely factual in General.
Guru Imakuni is offline   Reply With Quote
Old 09-13-2005, 02:49 AM   #8
svek
Member#: 82259
1999 impreza 2.2L
i used to, before i got caught up in OT. now i just post random shiat
Old 09-13-2005, 05:53 AM   #9
ilnmcom
Member#: 53557
2003 WRX - SOLD!
WR Blue Pearl
Just leave the NOS to the ricers. You're subie really doesn't need it. Find other ways to get more power into your car that are safer and won't hurt an otherwise reliable car.
ilnmcom is offline   Reply With Quote
Old 09-13-2005, 07:24 AM   #10
t3hWIT
Member#: 58779
95 STi RA (rhd)
like.....
...boost....
Old 09-13-2005, 07:30 AM   #11
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
sometimes boost hurts n/a suby's too
99subi is offline   Reply With Quote
Old 09-13-2005, 10:30 AM   #12
Lethargic1
Member#: 20998
It's your car. Personally, I wouldn't bother. I had a friend with an 01 RS that got a kit and everything and it sat in his room for like a year. He didn't want to bother with it either.
Lethargic1 is offline   Reply With Quote
Old 09-13-2005, 10:45 AM   #13
imprez25
Member#: 12479
1997 Jeep Cherokee
I'm always amazed at how people react or respond to nitrous questions. Just because you don't know anything about it doesn't make it "a ricers wet dream" or a bad thing.
As with any modification to improve a vehicles performance you have to look at it realistly otherwise you will be disapointed with the results. If you are thinking that you can install a 200 shot with no other upgrades and run 9's all day long. You will be dissapointed and end up with a blown motor just as installing an over sized turbo running maximum boost will end with the same results.
If you want to install nitrous be cautious, do your research, and mod slowly. Taking your time to do it right can result in a dramatic increase in performance with limited harm to your motor, self, or pedestrians.
To answer your specific question: I would look to upgrading the stock RS exhaust system (header + Cat Back). Make sure you run the appropriate spark plugs (for a 50 shot one step cooler will be sufficient). Make sure to get guages (bottle pressure, fuel pressure, ect). Engine management sould not be required unless you get a specific tune for nitrous (most EM advances timeing but when running nitrous you need to retard timing).
Good luck and like I said above, take your time and you will enjoy.
Sk.
imprez25 is offline   Reply With Quote
Old 09-13-2005, 12:18 PM   #14
scrmblr2
Member#: 24631
2005 STI
Thumbs up
Sk.
I commend you on some of the most well thought out responses to a question I have heard in a long time on this board. This is the type of response that got me interested in theis board in the first place.
scrmblr2 is offline   Reply With Quote
Old 09-13-2005, 01:13 PM   #15
kaisersouse
Member#: 85900
2001 Forester S
something something bottle warmer? (i know nothing about NOS)
kaisersouse is offline   Reply With Quote
Old 09-13-2005, 02:06 PM   #16
FalconRS
Member#: 92913
2005 2.5RS Wagon
Crystal Grey Metallic
Bottle warmer and bottle cover definitely improves consistency in using the nitrous setup. A small shot like a 50 is no big deal, you could probably even get away with a 75 jet but without full exhaust I wouldn't push it. A 50 shot can generally be used safely on most bone-stock cars, but your safety margin definitely goes up with a set of headers and a nice cat-back.
FalconRS is offline   Reply With Quote
Old 09-13-2005, 02:42 PM   #17
Pat L.I.
Member#: 20498
2006 WRX TR
there are many that have done it on the boards. I believe Kevin Thomas has nitrous on his RS but i may be incorrect.
Is it a wet or Dry kit. From the research i have done wet is safer.
I personally wouldnt feel comfortable with nitrous unless i had lots of supporting mods. wet kit, A/f guage,egt guage, knock link, a method for datalogging, method for adjusting timing and fuel.
Pat L.I. is offline   Reply With Quote
Old 09-13-2005, 06:00 PM   #18
gc822
Member#: 81217
if you plan on using it, just be careful you don't end up being like the dumbass who blew his engine as stated above.... personally i say screw the Nitrous, but thats IMHO.
gc822 is offline   Reply With Quote
Old 09-14-2005, 07:19 AM   #19
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
Boost is rougher on an RS than an equivalent shot of nitrous...
Do it.
jasona is offline   Reply With Quote
Old 09-14-2005, 09:29 PM   #20
AWDsub
Member#: 56303
2010 Legacy GT
Nitrous is fine I ran 13 bottles of a 75 wet shot on my last block with already 112k on it and it finally blew a hole in the piston. Cheapest mod with greatest horsepower just look at my dyno sheets with it. http://rallitekforums.com/forums/sho...0&page=2&pp=10
AWDsub is offline   Reply With Quote
Old 09-15-2005, 01:28 PM   #21
FalconRS
Member#: 92913
2005 2.5RS Wagon
Little bit of a wobbly torque curve but very nice gains. What sort of supporting mods did you have to pull 160 whp out of it before the nitrous?
Old 09-15-2005, 01:41 PM   #22
rally_on
Member#: 86849
2005 GMC Savana
white
id put nos in my car is a second, but i'd probably just show of with it, pull up to a stop light with a civic there and just shoot the nitrous purge a couple times to make them feel like sheet
rally_on is offline   Reply With Quote
Old 09-15-2005, 05:50 PM   #23
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
very nice numbers. I'm going to run a 100 shot in the near future and see what that gets me. I'm going to have all bolt on, cams, and the nitrous. I'm sure with a 100 shot the numbers will be even more crazy.
X4 SRT is offline   Reply With Quote
Old 09-15-2005, 06:21 PM   #24
Supapooh
Member#: 4461
02 2.slow
Simple supporting mods can benefit alot. Open up the engine and let it breath and you will gain even more with the nitrous. Add an svx fpr and wrx fuel pump and you should be able to run a 35-50 shot all day long. Now your clutch... that's a totally different story.
Supapooh is offline   Reply With Quote
Old 09-15-2005, 06:21 PM   #25
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Exclamation good luck
I hope you have some way of adjusting ignition timing. RS tend to run kinda advance tuning and that much N2O will be hard to tune safely without detonation and melted pistons. Even though N2O isn't always on, 100hp is still 100hp and will create similar cylinder pressures, putting alot of stress on the rotating parts(bearings, pistons, etc) Setting up a car to run really good with N2O usually follows in the same path as modding it for an aftermarket turbo kit, and can be equally expensive when you start to run alot of N2O.
John2.5RS is offline   Reply With Quote
Learning View screen shot - Good or bad? Ryan314 Open Source Reflashes 4 06-03-2010 11:44 AM
80,000 miles on a 2004 Subaru RS. Good or Bad? ahimsa Newbies & FAQs 9 05-18-2007 08:33 PM
5zigen Catback for 01 RS? Good or Bad? subietuner Tri-State Area Forum 19 08-25-2006 11:49 PM
('93-'01) rain-x on all windows.. good or bad?? iemonslice Impreza Forum 18 10-16-2001 08:56 AM
P7 rims w/ 215 tires on 2.5rs , good or bad? Blindeye_03 Brakes, Steering & Suspension 6 09-06-2001 11:50 PM
