#1 |
Member#: 88106
Vehicle:2010 2010 legacy GT Black mica |
My engine makes a knocking sound.. It normally ONLY happens when the engine is under a load, such as when you hit the gas or let the clutch out. I can usually get the sound in the morning by blipping the throttle a bit, and its definately present when im driving at lower rpm. I have had the hood open and gotten it to make the sound and its NOT coming from either cylinder bank im sure of that. I have it pinpointed to somewhere in the center of the engine, top or bottom i dont know...( guess i dont have it THAT pinpointed). Anyway....once the engine gets up to OT the sound gets much fainter and sometimes isnt even there.... I have had a few people tell me that it could be a rod bearing, call it denial, but i just want to hear if theres anything else this could be... One person in the troubleshooting section mentioned that it could be the oil pump...? If anyone has the same problem or has had it at some point let me know...
The only things that I have done recently, or since about the time i noticed the knocking was to change the oil ( i do it religiously) and replace the spark plugs, and PCV... And i have a drop in K&N, i know none of that prob makes a diff but thought i would throw it out there.. Owen
#2 |
Member#: 83961
Vehicle:2012 GLI/Subyless =( 2006 Triumph Daytona 675 |
did this get moved, or is it a double post?
anyway, still wondering what octane you're running |
#3 |
Member#: 88106
um, i posted it in two places...i need answers haha.. I run 87 all the time, i was told by the previous owner that running anything higher would detroy your knock sensor... i have run 89 once but i had the car LOADED with school stuff...
owen |
#4 |
Member#: 83961
running higher than 87 will destroy your knock sensor?
Im no RS expert, but I think that sounds like BS. We need some GC8 guys in here to confirm that. I would instantly have thought you are getting detonation running 87. |
#5 |
Member#: 51141
Vehicle:2013 WRX PBP |
^^^confirmed. I ran 89 all the time and my knock sensor went bad. I've used only 87 since then and its been fine (over 30k mi since)
#6 |
Member#: 88106
yeah i havent had any probs with running 87...well i do have this knocking sound....any other ideas?
owen |
#7 |
Member#: 58779
Vehicle:95 WRX RA replica, 98 Tacoma (300k Club) |
i always use 89 octane, and teh engine ran smoother, but no problems otherwise
i would bump the octane up a lil if your car is pinging. |
#8 |
Member#: 41012
E. Canada
Vehicle:1998 Legacy L |
If by knocking you mean ticking, then thats normal. Should sound like the wheel of fortune or a stick along a fence.
Its the lifters. Try changing your oil and see if it goes away for a while. Also, try using 5w-30 in the cold months. |
#9 | |
Member#: 53856
NESIC
Vehicle:2003 WRX Stage 2 taxi |
I agree with this statement. From what you describe it sounds like your lifters. Do you change your oil regularly?? That can make all the difference. ![]() |
#10 |
Member#: 58779
that reminds. me i always had a clicking that sounded like somebody taped a 3 of hearts to the cam gear. annoying, and kinda ratchety sounding, but i never had any problems related to it.
as for teh source? no flippin idea |
#11 |
Member#: 88106
na guys, i know lifter tick when i hear it i used to have a 94 probe gt and they have more HLA tap than anything... Its definately not that althought i appreciate the ideas... Im gonna take it to a garage soon and hopefully get it checked out...except for the whole Money thing...
Owen |
#12 | |
Member#: 80775
Vehicle:2005 2.5 RS Wagon Black |
#13 |
Member#: 62819
Vehicle:2002 Outback Blue/Titanium |
Pardon me, but I think the 87 octane ruining a knock sensor really seems like crap. It's a piezoelectric microphone bolted to the engine block. Changing the octane by a single grade doesn't create an extra violent vibration or loud denotation enough to damage the knock sensor. If that happens, there's something more to it. Most people run 87 octane as this is the recommended grade.
As to the knocking, could it be piston slap? I know you said it didn't seem to come from any specific cylinder, but this a common problem mistaken for knocking. I have it with my #2 cylinder especially. It does get better after it warms up. Mine has gotten worse and is now burning oil. FYI, Subaru said it wasn't bad enough to fix under warranty. It's been 20k miles since then. I've done the grounding mod, upgraded the wire set, spark plugs and air filter. This has made a difference even in how much better it sounds. |
#14 |
Member#: 19562
NESIC
Vehicle:93 Impreza wagon L Mud |
If it is from the center front check your timing belt tensioner.
#15 |
Member#: 11786
Vehicle:02 TS Black on White |
That's crazy. I've run everything from 87 to 110 octane in mine, and I ran nothing but 91+ for about 2 years.
#16 |
Member#: 89695
Vehicle:2005 Saab 9-2x Linear- Red |
Keep this thread going. My NA 2.5l Saab 9-2x has a spark knock that bothers me. Dealer said nothing wrong, but it has gotten worse. Does it at low speeds around town, but I took a trip this weekend, and it does it at 70mph highway speeds too. I have experimented with different grades of gas, to no effect.
#17 |
Member#: 81217
Vehicle:2013 WRX Stage I |
I highly doubt running 91 or 93 will kill anything on your car. Ran 93 octane on my '97 L for almost a year straight, my car is fine.
As for cars running "grumpy" after going from say 93 Octane down to 87, I believe it's just your ecu remapping or recycling to compensate for the lower octane. After running 93 octane for about 3 months I changed to 87 and shortly after the car started running like carp and threw a CEL. After I let it run a while, turned it off, ran it again the CEL went off and engine ran great. This happened twice. It has ran perfect not one complaint besides those two times I switched grades. ![]() |
#18 | |
Member#: 90849
Vehicle:2005 2.5RS Crystal grey |
| Thread Tools | |
| Display Modes | |
| knocking please help. | stattonmw | Factory 2.0L Turbo Powertrain | 1 | 12-30-2006 09:51 PM |
| engine knocking please help. | stattonmw | Factory 2.0L Turbo Powertrain | 1 | 12-30-2006 09:49 PM |
| wrx hits 10psi and knocks.. please help | mastershakewrx | Factory 2.0L Turbo Powertrain | 6 | 01-23-2006 04:33 PM |
| Knocking Please Help!!! | ODGC8 | General Community | 9 | 09-13-2005 03:30 PM |
| Strange noise maybe causeing false knock...please help!!! | bstoehr83 | Factory 2.0L Turbo Powertrain | 0 | 08-26-2004 02:05 AM |
