Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 09-13-2005, 09:35 PM   #1
blue dragon
Member#: 78020
Default possible motor swaps for 2.2L 97 legacy
I think my motor is dying, almost sounds like rod knock. What motor can I swap in there, and what years should I be considering. I know this is a noob question, but I appreciate the help in advance.
blue dragon is offline   Reply With Quote
Old 09-13-2005, 10:05 PM   #2
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
WRX motor swap.
If your going to stay with the 2.2 look for 96-99 legacy L or LS.
Don't know if the 1995 legacy's had OBDII
AFBeefcake is offline   Reply With Quote
Old 09-13-2005, 10:26 PM   #3
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
If he's going to use a 2.2L, He'll either need a 1996 and newer 2.2, or he'll need the dual port exhaust header. The 1996 and newer 2.2's had a single exhaust port instead of dual like the 1995 and older 2.2's.
The 1995's were TECHNICALLY Obd2, but they're missing a whole bunch of the emissions controls in the gas tank that the 1998's and newer had.
wrx_driver_2002 is offline   Reply With Quote
Old 09-14-2005, 02:15 AM   #4
MegaBeast
Member#: 78889
1998 Legacy GT
Green with WRX EJ20T swap
Do a WRX swap all the way
MegaBeast is offline   Reply With Quote
Old 09-14-2005, 01:38 PM   #5
blue dragon
Member#: 78020
Thanks for the info guys, not looking for anything crazy, its my winter car.
Old 09-14-2005, 04:02 PM   #6
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Off the top of my head,
H4: EJ18, EJ22, EJ22T, EJ25 SOHC and DOHC
H4T: EJ20 (WRX), EJ25 (Forester, LGT, STI)
H6: EG27, EG33, and EZ30
WRT the EG27 and EG33 (Old XT and SVX engines respectively) they are essentially an H4 with two additional cylinders added and timing "belt" driven cams. The 3.3 is a real torque monster.
The EZ30 is significantly shorter (only ~.75 inch longer than an EJ block) with sealed timing "chain" driven cams. Would be an awesome fit into your L. Expect long hours sorting out the wiring though.
What makes you think it's rod knock? Have you checked your cam tensioner? Can sound like rod knock or valve train noise but not nearly the hassle. See this Article for more info. Although it refers to 1999-2000 models, it may still apply to your's if it's failing/failed. Is worth a check.
Dale
Subietonic is offline   Reply With Quote
Old 09-15-2005, 09:51 AM   #7
blue dragon
Member#: 78020
^^ Definitely going to check it out, just have to pull the covers.
WTB: Knock sensor for 2.2L motor from L emsmap Private 'Wanted' Classifieds 2 11-26-2009 11:22 AM
Good salvaged car for 2.2L swap? GmRally95 Subaru Conversions 8 09-27-2009 09:04 PM
2.5 injectors in a 2.2l SOHC OBS? cams for 2.2l? kaisersouse Normally Aspirated Powertrain 3 04-02-2006 09:10 PM
In need of IACV for 90 2.2L MT legacy tuner-automotive Legacy Forum 0 10-31-2005 07:44 PM
2.5 Legacy Engine Swap for 2.0 Legacy brakemans Normally Aspirated with bolt-on Forced Induction Powertrain 2 08-20-2002 10:47 PM
