Old 09-13-2005, 11:31 PM   #1
EarlQHan
Member#: 90215
Default Legacy newbie here
Hi, I'm actually an Impreza owner myself, but my dad just got a 2005 2.5GT yesterday and I want to get him into modding the car Anyone know which mods first? I'm thinking tires, wheels, then I have no clue. It's an auto as he doesn't want to be hassled with driving a MT daily. Also, if I were to upgrade my car, which parts, if any, can be swapped over to the Legacy? Turbo? TMIC? (I have a 2005 STi). Thanks for all the help. Before you say "search", I would, but I wouldn't know where to begin for such a broad topic, and I'm slightly lazy :P
EarlQHan is offline   Reply With Quote
Old 09-14-2005, 01:00 PM   #2
Gil
Member#: 20872
t3h rubber-neckers
must die!
accessport
Gil is offline   Reply With Quote
Old 09-14-2005, 01:31 PM   #3
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
tell him to dump the RE92's
iamrazor is offline   Reply With Quote
Old 09-14-2005, 01:46 PM   #4
TRH_legacy2k
Member#: 66222
2000 Legacy
'68 Spitfire
legacygt.com?
TRH_legacy2k is offline   Reply With Quote
Old 09-14-2005, 03:12 PM   #5
sha_zapple
Member#: 41012
1998 Legacy L
new tires are a must, dont even give your RE92's to anyone, just burn them in the street
sha_zapple is offline   Reply With Quote
Old 09-14-2005, 04:01 PM   #6
TRH_legacy2k
Member#: 66222
2000 Legacy
'68 Spitfire
I'm down for free new tires! My standards are almost as low as my bank balance! HOYOOOOOOO!
Old 09-14-2005, 04:02 PM   #7
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
fibuz is offline   Reply With Quote
Old 09-14-2005, 04:18 PM   #8
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Tires AFTER the RE92s expire. The new 92a's are getting good mileage and are reasonable daily driver tires.
1st - rear sway bar. Helps to reduce body roll and makes the RE92s do their job that much better.
2nd - Uppipe - STI UP will bolt right up and take out the restrictive LGT UP cat - enables the LG "T" to spool quicker and bring boost on faster.
3rd - Access Port running Stage 1 map
4th - Downpipe with Hi-flow cat.
5th - Access Port Stage 2 map
6th - Cat-back Exhaust with mid-pipe eliminator and free-flow mufflers
7th - SS Brake line, HiPo Brake fluid upgrade and HiPo brake pads to haul this beast down from speed
8th - Big brake upgrade kit - Will require larger wheels and STI Brembo system will fit front (Not rears without modification)
Check out legacygt.com for tons more info on the topics above. Now you know what to search for...
Dale
Subietonic is offline   Reply With Quote
Old 09-14-2005, 07:32 PM   #9
EarlQHan
Member#: 90215
Thanks guys. I am now registered on legacygt, but they don't seem to get as much traffic as nasioc. anyone know where i can find legacy parts? anyone know which parts are interchangable other than the uppipe?
Old 09-14-2005, 08:30 PM   #10
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
I'd suggest not looking at the the traffic stats, that board has only been alive for the past 18 months or so and is growing by leaps and bounds. As I mentioned, there's tons of specific 05-06 LGT information, particulary what fits, where to get it, cost, etc.
Examples:
What's the cheapest way to mod your LGT
Vendor Reviews
As you'll find from your research, some of the STI bits will cross, especially since the LGT and the STI share the same engine block and internals. The STI turbo, intercooler and intack manifold will fit but must be switched out as a "set" since the stock LGT T, IC and I are different. When pieces don't fit piece for piece, there's an adaptor or workaround that will enable the STI parts to fit. Suspension, brakes and drivetrain share some similar components but will require more work to fit up.
Dale
Old 09-15-2005, 08:00 AM   #11
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
since you don't mind us spending your money... I'd get a set of bilsteins for it. all that power with only a RSB won't be too fun to drive.. IMHO, struts + springs are a must with all that power
Old 09-15-2005, 11:13 AM   #12
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
JDM takeoff Bilsteins are pricey ($750 plus) but are available. I've found that the LGT is an amazing handling car right out of the box. The RSB tightens it up very nicely. I'm currently running the JDM 20mm to replace the wimpy 16mm stock bar that is on the USDM Sedan and Wagon. Stock endlinks are really even good enough until you lower the car, then you'll want to think about adjustables.
I will agree that for spirited driving (particularly launch and stop) you'll want to upgrade the springs, probably to an Eibach Pro-kit like "progressive" spring. The STI Pink springs work great but they're not progressive and you feel significantly more of the road with that setup on stock struts. That said, the stock struts are pretty decent. If you can find the JDM Spec B, Rev A Bilstein setups, you'll likely be very happy with them.
Dale
Old 09-15-2005, 11:21 AM   #13
LegacyGt05
Member#: 80074
2007 BMW 335i
Sapphire Black Metallic
I have also been really happy with my iON Sport Springs, after I get my new rims/tires my next upgrade is for sure going to be a new rear sway bar.
LegacyGt05 is offline   Reply With Quote
newbie here here some pics of my rex before and after drkelly South East Region Forum 7 11-14-2003 07:34 PM
Legacy newbie with new legacy has a header Q Speed se-r Newbies & FAQs 1 03-24-2003 08:48 PM
newbie here... be gentle! Benjamin Tang Legacy Forum 20 02-28-2001 06:50 PM
newbie here jigcrates Newbies & FAQs 7 12-22-2000 06:11 PM
Any Father - Son Newbies here? pfobrien Newbies & FAQs 11 12-15-2000 12:44 AM
