09-14-2005, 01:33 AM | #1 |
Member#: 49958
Vehicle:'03 Cobra DSG SOLD '02 WRB WRX |
Off the shelf Stage 2 better than stock for fuel economy.
I have a UTEC and am running the stage 2 map with a few changes in boost, otherwise it is the base map. I know that the maps due run rich off the shelf to be safe. my question is, will the stage 2 map give my less fuel economy? I know it won't even be used when i'm cruising (less than 15% throttle), but any other time.
09-14-2005, 01:36 AM | #2 |
Member#: 60324
Vehicle:1998 RS |
in cruising closed loop, yes, open loop NO.
09-14-2005, 01:55 AM | #3 |
Member#: 36528
Vehicle:2002 Impreza Wrx Silver |
It should give around the same economy under 20% tps. Above 20%tps it depends on what your boost is set to. Ya might get better fuel economy at stock boost levels, but ya might not. I'd assume that you'd get worse fuel economy at higher boost levels.
peace |
Off the shelf pistons for a 2.1L stroker. | Touge Tune | Built Motor Discussion | 21 | 03-27-2008 09:45 PM |
UTEC: Off the shelf Stage 1 and 2 maps... | bpwatts | UTEC | 2 | 10-11-2006 05:54 PM |
Hot off the CNC! iON 2-piece front rotors for the MY05 STi <Weekend Sale> | iON Performance Inc | Suspension/Brakes/Handling | 1 | 03-07-2005 11:20 AM |
Can an off-the-shelf ECUTek reflash for vf34 with STi injectors be tuned with... | The Modaholic | Engine Management & Tuning | 2 | 12-26-2004 11:13 PM |
stage 4 setup, off the shelf map, how fast am i? | datdudedennis | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 04-14-2003 12:54 AM |
