Old 09-14-2005, 01:36 AM   #1
imprezdgc8
Member#: 87265
2007 Legacy Spec B
Question Where can i find an aftermarket intake for my 95 jdm ej20 motor?
I've got a 95 jdm ej20 motor in my gc8. I've got the exhaust done, the was easy because it was the same as the newer usdm wrx's. But i'm looking to get a better turbo inlet pipe. I can't find any that will fit.
Am i going to have to make a custom one, or does anybody know some that will fit and whatnot. I could make one easy, but gettin all the extra lines connected would be a bitch.
imprezdgc8 is offline   Reply With Quote
Old 09-14-2005, 07:06 AM   #2
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Do you have the 90 degree turbo inlet pipe??
DuoMaxwell is offline   Reply With Quote
Old 09-14-2005, 01:09 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
MRT makes some parts for your car's inlet. What parts are you looking for specifically? If you just wanted to do it stock, USDM Legacy turbo is the same. I have some of the parts in my garage...
Old 09-14-2005, 02:17 PM   #4
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
why do u want to mod the intake tract? have honda envy?
you loose power on a subaru with aftermarket intake.
supermoose is offline   Reply With Quote
Old 09-14-2005, 02:18 PM   #5
PowderMan420
Member#: 33737
what dont you have in your garage? all smartass comments aside would it be hard to change the 90 degree to the normal usdm style inlet?
PowderMan420 is offline   Reply With Quote
Old 09-14-2005, 02:50 PM   #6
imprezdgc8
Member#: 87265
2007 Legacy Spec B
i want to say yes i have the 90 degree but i'll have to go double check.
the main reason i want to change is because the plastic piece that put bov recirc back into the intake broke off, and since i have an atmospheric bov, i've just been covering it w/ ducttape, and that can't go on much longer.
it's just so big and clumpy, seems to me like a bigger diameter straigther inlet pipe would improve performance, but maybe i'm wrong. i'll post a pic up in a few hours.
Old 09-14-2005, 03:49 PM   #7
napphappy
Member#: 56170
95 Impreza L
Ugly
I broke the same piece
So I did a custom thing.
http://www.thawa.net/gallery/My-RS-RA/DSC00450
I routed all lines into the aluminium tube.
I now have a USDM WRX bov recirculated into the aluminium as well.
napphappy is offline   Reply With Quote
Old 09-14-2005, 04:02 PM   #8
supermoose
Member#: 9093
swap starr
u want a ricirc valve? i have one
Old 09-14-2005, 04:45 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
I've got the factory piece if you want the easy fix...
Old 09-14-2005, 04:57 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
If you want to convert to a straight style inlet, it is a fair bit of custom work. You will want to source a '97 or '98 intake manifold so the inlet pipe can go under it. The bolt pattern will be the same, and you can use the current USDM inlet. But you will still need to either change your turbo, or make a custom fitting for the inlet to mate to it...
Old 09-14-2005, 08:29 PM   #11
bmxpunk
Member#: 89599
1995 almost 22B:)
red
muggermod!!!!!
bmxpunk is offline   Reply With Quote
Old 09-14-2005, 10:37 PM   #12
imprezdgc8
Member#: 87265
2007 Legacy Spec B
so yeah, it's definately a 90 degree inlet. I think i'm going to have to go w/ a custom piece like napphappy. nice work by the way. Also, i have a k&n cone filter on there now... do u think i'd get better power running a k&n in the stock air box (shielding it from the heat)?
Old 09-15-2005, 01:59 AM   #13
supermoose
Member#: 9093
swap starr
you might want to ask the guys at kingpin who have alot of dyno experiance. several someones somwhere with alot of dyno time between differnt cars had reason to believe that keeping the stock airbox was the good.
Old 09-15-2005, 02:34 AM   #14
napphappy
Member#: 56170
95 Impreza L
Ugly
I have had both. It seems to idle better(maybe not highest HP, I dont know) with the Air box. But cooler air is almost always better.
You could put the cone in the inner fender(cool air) and see how it runs.
Old 09-19-2005, 05:11 PM   #15
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Do you have any idea how much a 97/8 manifold would go for? Or do you know anyone that is selling them?
subiekid is offline   Reply With Quote
Old 09-21-2005, 12:41 PM   #16
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
are you after the box or the elboe
i have the box .. cheep
the elboe is differnt between the usdm legacy and the ej20G the bov nipple points a differnt direction
Old 09-22-2005, 05:41 PM   #17
Matt Monson
Member#: 832
99 2.5RS, '85 911
I know I sound like a freaking broken record, but I have one. PM me with an offer. I was saving it to sell with the heads, but if the price is right, it's yours...
Old 09-22-2005, 05:43 PM   #18
Matt Monson
Member#: 832
99 2.5RS, '85 911
Actually, if you take a read in MRT's book called WRX training, they discuss this and do the math with temps and airflow, etc. What the math says is that the increase in airflow far outweighs the impact of the temperature, and that an open K&N filter on an early WRX is going to make more power...
Old 09-23-2005, 03:55 PM   #19
napphappy
Member#: 56170
95 Impreza L
Ugly
Interesting. That is if your intercooler is doing a good job. I would rather have a little less power than detonation.
Is that book available to read online? Sound interesting.
where can I find an initialization connector for an 02 ...lostwrx AccessPort 11 07-05-2009 05:28 PM
where can I find an NPT fitting for an Autometer EGT probe? Anyone have an extra? Wagon Joe Electrical & Lighting 0 09-20-2004 05:02 PM
Where on the internet can i find an aluminum hood for my 2000 RS? WRC1 Private 'Wanted' Classifieds 3 06-15-2004 06:48 PM
Where can I find a aftermarket turbo for an Impreza? LPaudio Newbies & FAQs 1 09-14-2002 09:27 PM
('93-'01) where can i find clear directional lenses for my 99' RS? ILUVMY2.5RS Impreza Forum 4 09-26-2001 01:57 AM
