Old 09-14-2005, 03:22 AM   #1
Vtecready
Member#: 92106
Default 04 STi idle bouncing.
When I drive my STi kinda hard 5500 max revs the idle will drop to 1000 then bounce to like 1500-1800 and then drop back to idle at 500. Is this normal or what.
Vtecready is offline   Reply With Quote
Old 09-14-2005, 08:10 AM   #2
happasaiyan
Member#: 37731
yeah, seems normal.
happens to me every so often.
ps- your car doesnt idle at 500
happasaiyan is offline   Reply With Quote
Old 09-14-2005, 07:18 PM   #3
Vtecready
Member#: 92106
Wanna bet it doesnt idle at 500 rpms.
Old 09-14-2005, 07:33 PM   #4
4EVO2NV
Member#: 51692
04 STi JBP
Enginuity Tuned
ill take the bet that it doesn't
4EVO2NV is offline   Reply With Quote
Old 09-14-2005, 08:21 PM   #5
Vtecready
Member#: 92106
So if I take a pic of it you guys will believe me.
Old 09-14-2005, 11:08 PM   #6
happasaiyan
Member#: 37731
how much do you want to bet? im game.
Old 09-14-2005, 11:27 PM   #7
Vtecready
Member#: 92106
haha I looked closer and its even with the bar cant tell if its 500 or not.
Old 09-15-2005, 12:03 AM   #8
happasaiyan
Member#: 37731
wheres my money?
Old 09-15-2005, 01:10 AM   #9
Vtecready
Member#: 92106
Originally Posted by happasaiyan
wheres my money?
Aha damn I feel dumb now.
Old 09-15-2005, 01:16 AM   #10
hatchy
Member#: 36852
2004 STI
Is your car stock? My car behaves this way too, but only after Ecutek reflash, green, pe850, bigmaf. Only seems to happen when in neutral.
hatchy is offline   Reply With Quote
Old 09-15-2005, 03:59 AM   #11
Syms-STI
Member#: 87463
2004 STI
AspenWhite
haha i fell for that once before.... so dont worry
Syms-STI is offline   Reply With Quote
Old 09-15-2005, 01:21 PM   #12
titsataki
Member#: 4402
I would bet that if one connects an OBDII software or DelataDash the idle will be at 740 rpm.
What you are inquiring is that when you shift between gears and then you either press the clutch in or put it in neutral as you come to stop the idle take a few extra seconds to come to a steady 740. Which is pretty normal. Now if you start the car bring it to a complete warmed up stage and then the idle is not at 740 while you stay still, then you may want to run some logs to see what is going on. If the car is stock take it to the dealer. Also the idle may not be perfect after you reset the ECU as it adjusts trimming etc.. If you have aftermarket injectors etc.. it becomes even more difficult and it is very much based on tuning.
Regards
Nick
titsataki is offline   Reply With Quote
Old 09-15-2005, 01:42 PM   #13
WRXout
Member#: 52908
2005 WRX STI FTI 20G
ASPEN WHITE
or dirty mad sensor
WRXout is offline   Reply With Quote
Old 09-16-2005, 09:42 AM   #14
cboggess
Member#: 30804
87 Yugo
Red
Originally Posted by WRXout
or dirty mad sensor
I hate it when those sensors get angry.
cboggess is offline   Reply With Quote
Old 09-16-2005, 03:26 PM   #15
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
I changed plugs today and removed the battery wich caused ECU to reset.The first thing I noticed was that my STI was dropping to 500(the first line) then back to 750 when coming to stop signs.It idled ok when it was cold at high idle,but started jumping after driving and coming to stops.I hope it is just from resetting the ecu.I never noticed this before on my car.Will it come back to normal after a while?
Old 09-16-2005, 05:12 PM   #16
wile2k
Member#: 58444
'02 Z06
Millenium Yellow
I had something similar on my car. I went with a different tuner after I got my FMIC and catback and on that tune, the car would learn in (after running for 50+miles) and then when coming to a stop the idle would surge up to 1500-2000 then drop down. Drove me up the wall.
Well, long story short, I was never happy with the refineness of the tune, so I went back to my original tuner and theirs is smooth as silk and doesn't throttle up as excessively when coming to a stop. I think the high idle on stop is normal up to about 900rpm then settling to the specified idle, but 1500-2000 was just annoying and wrong.
For me, it was definatly in the tune.
wile2k is offline   Reply With Quote
Grinding Noise at Idle on a 04 STi ! viaburn26 Transmission (AT/MT) & Driveline 2 04-23-2008 03:34 AM
my Impreza's idle bounces! 04.STI Normally Aspirated Powertrain 7 02-07-2007 03:58 PM
04 STi Idle Issues RR02wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 12-09-2006 03:58 PM
04 STi idle at 1500? j2los Newbies & FAQs 4 10-17-2006 02:58 PM
