Old 09-14-2005, 01:37 PM   #1
Odin_2
Member#: 94142
2002 Impreza OBS
Question Rough idle with A/C on
I recently bought a 02 OBS, and whenever my a/c is on and i'm at idle and I have the car in drive (yes i have an auto ) the idle is very rough and it comes and goes as the compressor turns on and off.
If I put the car in neutral the rough idle goes away.
Is there anything I can do to help get rid of this rough idle when the A/C is on?
Would doing the ECU / TCU reset thing I've read about help any?
Odin_2 is offline   Reply With Quote
Old 09-14-2005, 01:51 PM   #2
shemoves
Member#: 80663
2005 STi
It is most likely that a belt is loose, worn, or both. Get it checked out ASAP.
shemoves is offline   Reply With Quote
Old 09-20-2005, 11:17 AM   #3
Odin_2
Member#: 94142
2002 Impreza OBS
I have checked out the belt and it seems fine, it only has 20k on it i dunno if that matters or not
It just doesn't seem like a belt problem because the RPMs are lowering when the AC is kicked on and that is when the rough idle starts. could it be the IAC sensor or something? Like I said above if I kick it into neutral the RPMs raise a little and the roughness goes away completely.
When I got the car from the dealer it was doing this and they said it was normal but I've never had a car act like this before. It just seems a little exessive.
cold start rough idle with helix 820cc injectors sonic rx Commercial ECU Reflashes 5 05-30-2006 09:11 AM
Looking for opinion on poor idle with A/C on Procyon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-17-2006 04:42 PM
Rough idling when fan is on whitegdwagon Electrical & Lighting 3 02-18-2005 11:43 PM
Rough idle at 8000 miles on WRX could it be the fuel injectors? cky211 Service & Maintenance 12 07-01-2003 02:33 AM
booty shaking idle with a/c on RaceCarRiot Normally Aspirated Powertrain 0 01-15-2002 12:58 PM
