#1 |
Brain Stew
Moderator Member#: 4562
NWIC
Vehicle:1998 Forester,lifted 1975 VW Westfalia tin top |
Yep, Co-worker bought an old Minnam kit for his RS, so you guys will be seeing more of my traitor ass in here
![]() So whats the new engine management of choice for the RS? Any places to still buy a P&P harness for the Link plus? ![]()
#2 |
Member#: 1366
VIC
Vehicle:2000 RS-T -> RSTi-8 Blue Ridge Pearl |
Link+ is dated but cheap - if you don't mind piggybacks, eManage and PerfectPower seems to do the job. Depends on whether you need OBD-II, I wouldn't remove the stock ECU at all. I just wish i-Speed made an RS-T reflash but they didn't...
#3 |
Member#: 9861
RMIC
Vehicle:1999 2.35 RS-T w/NOS Hybrid Rally Blue Pearl |
Autronic here
#4 |
Member#: 39936
Vehicle:99RS TWE&SCAT EJ257 Hydra+HMist+PPG+35R=DEATH |
P&P harnesses are very hard to find outside of the manufacturer
and QUITE expensive its almost more cost effective to buy an emanage for what its worth |
#5 |
Member#: 2604
NESIC
Vehicle:1999 2.5RSt RBP |
emanage ultimate if you are going to get an emanage
#6 |
Brain Stew
NWIC
I never liked the E-manage, I just have experience with the Link (and loved it)
He is considering a Hydra at this point. What the hell is a Hydra?? |
#7 |
Member#: 7022
Vehicle:2013 BRZ Limited SWP |
A local has a hydra on his RS. Seems to like it. Seems like the link is still the way to go. I keep hearing about this perfect power but don't know much about it.
Wish it was as easy as wireing in a wrx ecu and getting a reflash. |
#8 |
Member#: 11616
Vehicle:1998 2.35RS-T 2006 Baja 2007 Leg. Wagon |
Hydra -- they can hook you up with a p&p harness -- I haven't had much time to play with mine yet to tell you how i like it but its good so far.
#9 |
Member#: 30798
Vehicle:2001 RS-T Hybrid 2.5>2.2T>257>2.35S |
I vote for the link+ as well. A local guy just picked one up off rs25 for 500. Might look over there. I've heard good things about autronic as well but it's rather expensive.
P.S Why didn't you put a 3" downpipe w/ a wg dump on the car to begin with it would have saved me from having to have on fabricated. ![]() |
#10 | |
Member#: 80663
SWIC
Vehicle:1997 Outback |
2. multi-headed dragon |
#11 | |
Brain Stew
NWIC
Pm SubEd for details I wanted to run WRX and VF-series turbos on it. ![]() |
#12 | |
Moderator Member#: 922
Vehicle:04 FXT Red |
#13 |
Member#: 49831
NWIC
Vehicle:2008 Get Tuned Now Knowledge is Power |
Autronic for me
![]() Ben |
#14 | |
Member#: 1366
VIC
)I guess there are still a few RS-Ts running around with Link+ and doing OK. |
#15 | |
Member#: 7022
#16 |
Member#: 11354
Vehicle:2009 LGT BF3 tag: Snbrd4evr |
I have a hydra. I love it, autotune, closed loop is really easy to control and set up. But it's all up to you, go with what you know
#17 |
Member#: 8533
Vehicle:2002 2.5 RS-T LudeSpeed S. III W/ FMIC |
I'm still running the Link + as well, but I've been trying to find a PNP harness w/ little luck. I want to start developing an RS-T reflash, but I need to be able to swap back and fourth easly and right now it's hardwired in. Let me know if you find anyone who still has them in stock.
-Jared. |
#18 |
Member#: 1366
VIC
Actually, who can obtain the plugs for both side (stock ECU and stock harness)? I suppose those plugs are expensive enough that I shouldn't bother trying to make my own PnP harness? Those PnP harness are getting awful hard to find used, let alone new
#19 |
Member#: 8533
The Link Side comes w/ the link. If you feel like picking up a stock ECU from the junk yard you can get the other end that way.
If anyone is going to do this, let me know & I'll try and dig up the pin out I had for a PNP harness a few years back. It's not hard to piece togeather, but I had it in excell format, and if the work has been done why repeat. It's been tested, so you know it will work on the first shot. -Jared |
#20 |
Member#: 1366
VIC
So that's how the plugs are made - junk yard ECU and harness. I just wish someone in the plastic industry can clone those and not get sued
#21 |
Member#: 8533
There was a guy on here back in 01 or 02 that knew where to get them in bulk from a supplier. He had to buy them in min qty of 1,000, and I don’t know if he ever got them or not. I’m sure they can be sourced, it’s just easier to hit up a wrecking yard.
And you only need the ECU side beings you plug the PNP harness into your existing chassis harness. -Jared. |
#22 |
Member#: 1366
VIC
Unless of course you need to run Parallel Engine Management with the stock ECU
#23 |
Member#: 8533
Parallel??? I guess you could use both sides of the harness if you planed to run a piggy back w/ the stock ECU, but the PNP harnesses were typically so that you can swap your stock ECU out w/ a stand alone w/o any cutting or soldering
#24 |
Member#: 1366
VIC
Yes, for something like a Link+ that can handle everything in the car, I can see that you can go without the stock ECU. Except no aftermarket ECU supports OBD-II, and I certainly don't want a blown motor during smog check running the stocker
| Thread Tools | |
| Display Modes | |
| LeeC is Back in the Subaru Game! | LeeC | Member's Car Gallery | 54 | 04-29-2010 06:34 PM |
| My New 08! I am back in the Subaru Game! | Touge86 | Member's Car Gallery | 18 | 12-11-2008 04:13 PM |
| Back in the dating game advice... | Spitfire999 | Off-Topic | 44 | 06-26-2007 09:23 PM |
| Want to get back in the Scoobie game! | GooseMan | General Community | 10 | 08-15-2006 02:42 PM |
| So I want to get back in the Subie game.... | GooseMan | Legacy Forum | 14 | 08-14-2006 01:36 PM |
