![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 4881
Vehicle:2001 2.5 RS BRP |
I'm thinking of putting these on.
They're 5x100/114.3 40 (18's). What do you think? ![]() |
#2 |
Member#: 2918
Vehicle:2002 Impreza WRX Silver Sedan |
Offset is 40? A bit lower than you normally want to go. I would think Rubbing might be a problem.
#3 |
Hoodbridge!
Moderator |
40mm offset is way too low for a Subaru. You will have fender rubbing, and eventually, premature wheel bearing failure.
#4 | |
Member#: 1931
Vehicle:2000 00 impreza 2.2l wagon |
-wop |
#5 |
Member#: 9507
Vehicle:2002 WRX Sold...for a race car |
I have 18" X 7.5" with 38 offset, and I rub on high G corners. I'm putting on 1.5" and 1" lower springs next week, and I know I will have to roll the fenders.
#6 | |
Member#: 1931
!!! -wop |
#7 |
Member#: 484
Vehicle:2001 OBS SRP |
Actually, Enkei makes some of the OEM aluminum rims for Subaru so they know what fits Subaru.
Also, some wheel manufacturers measure offset differently than Subaru. I measured my Enkei's that said +40 on them the way Subaru measures wheels and came up with +48. Then I measured the +55 steel wheels that came with my Subaru the way that Enkei measures offset and came up with +47. My advice is to measure your OEM wheels and then measure the ones that you want to buy and compare YOUR measurements. Don't go by what the wheel or car manufacturer says. Sean |
