Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 09-15-2005, 12:00 AM   #1
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
Legacy N/A legacy 2.2 fuel pump specs
you guys did a great job answering my questions about legacy turbo injector flow rates. Now all i need to know is how much the N/A fuel pump flows, preferably in lph but idk if thats how they are rated by subaru.
thanks so much
Justin
Kawikid20o2 is offline   Reply With Quote
Old 09-15-2005, 04:43 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Discharge pressure is 36.3 psi
Discharge flow is rated at "More than 80 lph" at the following voltage/pressure [12V at 36.3 psi]
Legacy777 is offline   Reply With Quote
Old 09-15-2005, 09:10 PM   #3
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
it only flows 80 lph???
Old 09-16-2005, 01:58 PM   #4
Legacy777
Member#: 4800
That's what the factory manual says.....
I can double check a different manual when I get home, but it's probably correct.
Old 09-16-2005, 02:03 PM   #5
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
do you know what color injectors the car had that you reading out of the manual from?
Old 09-19-2005, 10:47 AM   #6
Legacy777
Member#: 4800
Red.
However the 90 & 91 n/a legacies had the same rated pump, but their injectors were grayish for the AT and black I believe for the MT's.
Old 09-19-2005, 02:15 PM   #7
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
so it doesnt matter what injectors the car had, they all share the same fuel pump? probably with the exception of the turbo model with the pinks we talked about in my injector thread.
Old 09-19-2005, 02:21 PM   #8
Legacy777
Member#: 4800
Correct
The part # may have changed, but the pump's specs stayed the same.
Old 09-19-2005, 11:36 PM   #9
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
ok thanks a bunch!
Old 09-21-2005, 02:12 AM   #10
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
ok so i did a little home work and converted the 360cc/min flow of the turbo injectors to LPH.
360cc/min x 60 = 26,100cc/hr
26,100cc/hr to LPH move decimal 3 places left = 26.1LPH
26.1LPH x 4 injectors = 86.4LPH max flow
do i have a problem running an 80LPH pump at the top end?
Old 09-22-2005, 02:29 PM   #11
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
just need to know if i can get away with it or not or if i messed up calculating stuff
Old 09-23-2005, 12:35 PM   #12
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
It would not be a good thing. You would probably run a bit lean at the top end, where you need the fuel most.
If it could keep up, you would be running it harder than it was designed for, thus shortening its life.
I would recommend just replacing it with a high-flow unit. I put a Walbro GSS-341 255 LPH unit in mine. It was drop-in, and less than $100.
IronMonkeyL255 is offline   Reply With Quote
Old 09-23-2005, 02:12 PM   #13
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
yours was turbo from factory right? So do you have the OE pump for your car? it should be a 150lph...i would be interested in it if you do.
Old 09-30-2005, 12:31 AM   #14
Legacy777
Member#: 4800
I've got a spare turbo legacy pump if you'd like to buy it. I used the walbro 341 instead of the stock one.
Let me know if you're interested.
Old 09-30-2005, 01:35 AM   #15
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Subaru Stars
i might have a wrx pump becoming availible to me shortly, but if that does not happen i might be interested in yours.
FS OH: Greddy E-manage Blue, custom UP, mod. BPM DP, intercooler, 2 wrx fuel pumps AWDrivin Engine/Power/Exhaust 16 03-18-2007 10:02 PM
WRX vs. STi fuel pump specs? Bayley Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-04-2005 11:26 AM
99' Impreza 2.5RS fuel pump GC8STIV2 Private 'For Sale' Classifieds 0 10-30-2004 02:13 PM
TRADE: stock WRX fuel pump for 2.5RS fuel pump. Riverside CA RyansJDMgc8 Private 'For Sale' Classifieds 0 07-05-2004 07:47 PM
Legacy and Impreza fuel pumps scoobyimprza Subaru Conversions 2 07-31-2003 01:10 PM
