Old 09-14-2005, 11:50 PM   #1
Flexy
Member#: 34028
2000 Legacy GT
Titanium
Default Oil in spark plug tube
http://ca.pg.photos.yahoo.com/ph/andrey_x/my_photos
I was changing spark plugs today and when I pulled the plug rubber boot, I saw oil(red colour on the picture) there on the bottom of the ring, between the outer and inner ring. Does this mean that I have gasket leak? No noticable oil consumption. Please give me your input.
Flexy is offline   Reply With Quote
Old 09-14-2005, 11:52 PM   #2
pityr
Member#: 31719
maybe you didn't tighten the plug enough when you last changed them.
pityr is offline   Reply With Quote
Old 09-15-2005, 12:05 AM   #3
Flexy
Member#: 34028
2000 Legacy GT
Titanium
I do not think plugs were changed before me.
Old 09-15-2005, 12:12 AM   #4
pityr
Member#: 31719
maybe they got loose or some oil was spilled in that area. I dont think there are very many ways other for oil to get in there if it doesn't come from outside or from within the cylinder head.
Old 09-15-2005, 12:19 AM   #5
Flexy
Member#: 34028
2000 Legacy GT
Titanium
I am not sure about that. Also I forgot to mention that both of holes on the left side of the engine have same issue. Plugs on the right side of the engine are fine.
Old 09-15-2005, 12:33 AM   #6
pityr
Member#: 31719
guess it could be the valve cover gasket although im not sure exactly how that fits together. I do know that on my old MR2 if the gasket wasn't set just right you could get some oil in the spark plug holes.
Old 09-15-2005, 07:48 AM   #7
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
The valve cover gasket is leaking (specifically the spark plug tube seals).
Brian
Old 09-15-2005, 08:32 AM   #8
Daishi00
Member#: 78952
2005 WRX
CGM
Brian
Yup. Just had this happen to my other car (Rubbermaid Rocket).
Daishi00 is offline   Reply With Quote
Old 09-15-2005, 12:31 PM   #9
Flexy
Member#: 34028
2000 Legacy GT
Titanium
What are the dangers of this gasket leaking? How much aproximately will it cost to fix that?
Old 09-15-2005, 01:07 PM   #10
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
What year/mileage car do you have? May be covered under powertrain warranty
RexyGirl is offline   Reply With Quote
Old 09-15-2005, 02:49 PM   #11
Flexy
Member#: 34028
2000 Legacy GT
Titanium
2000 Legacy GT with 72 000km.
Old 09-15-2005, 03:06 PM   #12
Flexy
Member#: 34028
2000 Legacy GT
Titanium
Anyone has instructions on how to change those gaskets?
Old 09-15-2005, 05:45 PM   #13
MK1ofMnM
Member#: 6976
2006 F150
If left alone the oil will eventually deteriorate the the rubber spark plug boot. The seals aren't hard to change though. Just pull the valvecover.
MK1ofMnM is offline   Reply With Quote
Old 09-15-2005, 06:46 PM   #14
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Tim Sanderson is offline   Reply With Quote
Old 09-16-2005, 08:41 AM   #15
RexyGirl
Member#: 63616
with mods :)
I think Canada's powertrain warranty may be a little different, but check to see if you are still under it. If so, it is a covered component under powertrain
Old 09-16-2005, 09:33 AM   #16
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
It's 5 bolts per side to take them off, and then you need 10 bolt grommet seals, 4 spark plug tube seals, and two valve cover gaskets. You can easily do this in the car in under 2 hours, probably under an hour if you are familiar with tools.
Brian
Old 09-16-2005, 12:17 PM   #17
Flexy
Member#: 34028
2000 Legacy GT
Titanium
Called the dealer last night, warranty expired this July I will perform this job on my own I guess. The only trouble I will have is torquing the bolts, I don't have the torque wrench, so I will have to use my hands. It's very crusial to tigthen them right.
Oil in spark plug area orndog Service & Maintenance 3 01-29-2007 09:57 AM
Oil in spark plug hole 7andSubie Owner Normally Aspirated Powertrain 3 09-18-2005 12:52 AM
2.2L Crankshaft Positioning Sensor needed - also, oil in spark plugs question marcus12 New England Impreza Club Forum -- NESIC 10 01-11-2005 02:49 PM
Oil in spark plug hole, 91 2.2??? rallynutdon Legacy Forum 8 10-22-2004 12:08 PM
Oil in spark plug NickSTi South East Region Forum 8 08-27-2002 08:55 PM
