Old 09-15-2005, 09:55 PM   #1
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Default odd knocking sound
Okay, it sorta sounds like piston slap, but it isn't, I don't think.
There is a sort of clicking sound (fairly rapid) that is coming from somwhere down where the plug wires go into the block, and I'm wondering what it is. Any ideas??? The car is driving the same as it always did.
I have an EJ22, 5MT, new plug wires and spark plugs, 5w-30 oil...
Thanks in advance
Wiscon_Mark is offline   Reply With Quote
Old 09-16-2005, 12:39 AM   #2
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
Legacy
you need to check how well 'new' plug wires are connected. if its not that then you have a valve tap.
Kawikid20o2 is offline   Reply With Quote
Old 09-16-2005, 01:07 AM   #3
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
I would suspect cam belt tensioner. Check out this Need Help Thread for mor info.
Dale
Subietonic is offline   Reply With Quote
Old 09-16-2005, 06:14 PM   #4
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
I'll check it out soon, because my timing belt probably needs replacing soon. I've got Subaru Credit too Probably get serpentine and timing done all at once, then the tensioner can be checked.
another detail that might help you guys out:
The car wasn't being run much for the last six weeks as the cat pipe rusted through and the car was illegally loud so I didn't drive it much. I did keep it fresh by running it every week or so...could have something to do with it?
Old 09-16-2005, 08:53 PM   #5
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
if it was just idled, i dont see why that would cause any thing...the only problem with not having an exhaust is revving it with out ne back pressure. They usually dont like that.
Old 09-16-2005, 09:05 PM   #6
lag
Member#: 34631
to live in fear
It may be that your plug boot isn't seated correctly, spark jump can be very loud. Other wise I'd go with valve tap, is it only on one side or both?
lag is offline   Reply With Quote
Old 09-16-2005, 11:42 PM   #7
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
both sides
kawikid-I have exhaust on now, it was sitting mostly when the cat pipe was leaking, then I got it fixed and it became my DD...
Old 09-17-2005, 01:48 AM   #8
lag
Member#: 34631
to live in fear
did you remove the exhaust from the heads? You may have a leak there, allot of people mistake that sound for piston slap.
Old 09-17-2005, 04:23 AM   #9
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
have someone plug the exhaust temporarily while you listen to it run up front. If the sound changes, then you definitly need to check out the E. Manifold gaskets
or flanges prolly gaskets.
Old 09-17-2005, 08:06 AM   #10
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
headers have not been touched, it was only the cat that was replaced. And I only hear the sound up near the spark plug area, its not so loud that you hear it in the cabin or out the exhaust...
Old 09-17-2005, 02:38 PM   #11
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
If it's coming from the plug area, check your spark plug connections.
Service information reminder: Before condemning a Subaru engine for having an engine knock or a valve tap, make certain that all the spark plug wires are firmly connected to their corresponding spark plugs, The spark plugs are deeply recessed in the cylinder heads, so the sound that is produced by a loose plug wire can easily be confused with valve tap or piston slap.
Just an additional thought, especially if you replaced the plugs/wires. I've actually done this before. Car ran okay but the taping noise was distracting, especially after a complete tuneup.
The odd ticking noise may actually be the spark arcing to ground or to the plug itself.
Dale
Old 09-17-2005, 02:39 PM   #12
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
yeah, I'm gonna check that, because it sounds more like a click than anything, and the car is running great...thanks for the advice everyone
Old 09-17-2005, 02:48 PM   #13
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
Im pretty sure i said all that stuff about the plug wires up there
Old 09-17-2005, 07:07 PM   #14
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Yes, you did.
Old 09-17-2005, 09:57 PM   #15
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Yes you did. I was just validating it from a Subaru article on it.
Dale
Old 09-18-2005, 12:25 AM   #16
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
Legacy
ok then...sorry for sounding like an a** i was just making sure that i was being taken seriously.
Old 10-16-2005, 06:16 PM   #17
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Funny this came up, because I had a similar noise on my 2002 WRX. It was rpm-dependent and coming from down by the driver side spark plugs. It turned out that my plug was not sufficiently torqued in the block and was rattling slightly.
nhluhr is offline   Reply With Quote
Old 10-16-2005, 07:52 PM   #18
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
yeah, I have yet to do this. I think I'll ask my dad for the tools and check it out. Its not so loud when its warm (warm=expansion) so I'd guess its something loose.
knocking sound from engine 2500- 3000 rpm. rod knock? NITROS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 01-17-2014 04:05 PM
Knocking sound after a run. Stumped, sounds like the pistons? MarylandEcstasy Service & Maintenance 14 05-30-2006 10:38 PM
Odd knock issue (UTEC, VF34, etc) odyss3y Engine Management & Tuning 14 11-16-2005 12:06 PM
odd knocking problems CpnNeeda Engine Management & Tuning 0 11-13-2003 04:46 PM
Odd knocking/ticking sound? Deeman81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-23-2003 08:20 PM
