#1 |
Member#: 73684
NWIC
Vehicle:2012 4Runner |
Anyone who has taken their tail lights out: Is it easy? Anything to look out for? I remember reading somewhere about a lot of grease being involved
Thanks Mitch
#2 |
Member#: 8048
International
Its pretty simple. Just pull out the lining to expose the hex nuts and there you go. But the lining is rather sharp and you should wear gloves. I think I did a writeup of it when I changed my lights 3-4 years ago.
#3 |
Member#: 12588
SCIC
Vehicle:Four Count 'em GF5,BDA,BD5, BP5 |
You will likely have a bunch of adhesive/sealant between your lense units and your body so be prepared to deal with that. Patrick Olsen just did his rear taillights so do a search on this forum and you'll see several "tricks" for decreasing your frustration and that get you in and out of the rear taillight removal that much quicker.
Dale |
#4 |
Member#: 41308
Vehicle:2006 ABP Legacy GT '02 F4i / '07 ZX-10R |
The outer two pieces (where your turn signals are) were relatively easy for me to get off, but the center piece was a huge PITA with the sealant stuff that was on there.
Otherwise yeah - just find all the crazy bolts holding them in, and pry em off as carefully as you can. |
#5 |
Member#: 53410
SWIC
Vehicle:BE-> GD->GR->SG->BL WAawd.org |
There wasn't any crazy amounts of adhesive when I did mine...I think theres like 8 bolts on the inside of the trunk...pretty easy. 15 minute removal if that. Just unbolt, and pull off(very little muscle required).
fibuz |
#6 |
Member#: 56015
RMIC
Vehicle:No you're a towel! |
I think the BE just has the bolts but the previous models where glued in.
#7 |
Member#: 12588
SCIC
Glued, screwed and tattooed (j/kabout the tattoo)
#8 |
Member#: 73684
NWIC
Thanks for the info guys. I'll let ya know how it goes this weekend.
#9 |
Member#: 38222
Vehicle:'10 &'12 Foresters another Miata convert |
8 bolts, Fibizzle? I had two studs on each side... pushing the lens inward a little bit, I could loosen them with my fingers.
| Thread Tools | |
| Display Modes | |
| removing minor scratches from new car | RS 1986 | Car Care & Detailing | 27 | 06-06-2010 09:19 PM |
| BE dash removal. HELP! | iamrazor | Legacy Forum | 9 | 05-05-2007 05:36 PM |
| GC8 Taillight Removal | eurojax | Electrical & Lighting | 2 | 11-22-2003 03:16 AM |
| How easy would it be to remove the keyless entry system? | Corn-Picker | Car Audio, Video & Security | 1 | 08-15-2002 06:19 PM |
